Front driveshaft Spicer U-joint part numbers?
Old Sep 19, 2016 | 03:33 PM
Dextreme's Avatar
I have been searching all morning and can't seem to figure out which Spicer Front Driveline ujoints I need to order. I would like to replace all three with non-greaseable as well as the centering yoke for the cardan.
Not sure of my drivetrain series, but it is a 2004.5 Cummins 3500.
Anyone have Spicer part numbers?
Old Sep 20, 2016 | 06:08 AM
saggonwaggon91's Avatar
If I may ask, why would you want the non-serviceable u-joints?
Old Sep 20, 2016 | 08:50 AM
johnh's Avatar
i can answer that , he knows that joints w/out grease fittings are stronger and will last as long or longer than grease able ones, for example, mine are original at 300,000 miles
Old Sep 20, 2016 | 01:21 PM
Dextreme's Avatar
Yep...I prefer non-greaseable as they are stronger. It is also what I use in my Wrangler.
Old Sep 20, 2016 | 01:38 PM
IC. Learn something new everyday...
Old Sep 20, 2016 | 03:25 PM
TopperHarley's Avatar
Here is a post I made back in January in this thread https://www.dieseltruckresource.com/...-286794/page2/ when I bought Spicers for my '05 short bed 4x4....
For anyone else trying to cross-ref the correct P/N’s for the Spicers, here are the updated numbers for both the Lifes and the greaseables…
2x Front Axel: 1.375” length, 2.920” cup diameter, Inside Snap Ring
.......Lifes - 5006813
.......(no greaseables available)
2x Rear Shaft (short bed, one piece shaft): 1410 Series - 4.188” length, 1.188” cup diameter, Outside Snap Ring
.......Lifes – 5-1410x (replaces obsolete 5-801x). This kit comes with multiple snap ring sizes for easier installation.
.......Greaseables – 5-160x
1x Front Shaft, front joint at pinion: 1330 Series - 2.556” length, 1.125” cup diameter, Inside Snap Ring
......Lifes – 5-795x
......Greaseables – 5-3147x
2x Front Shaft, center/rear joint at CV: 1350 Series – 3.625” length, 1.188” cup diameter, Outside Snap Ring
.......Lifes – 5-1350x (replaces obsolete 5-799x). This kit comes with multiple snap ring sizes for easier installation.
......Greaseables – 5-178x
Hope that helps you out.
Old Sep 26, 2016 | 10:13 PM
2-Stroke's Avatar
I was just copying the link that thread for him... Spicer Life Joints are the best I've found. Don't even bother with a corner store set.
Maybe a Mod can pin it to the top given its likely the end of life for most stock u-joints for our year trucks...
freight train
Nov 29, 2011 10:58 AM
realest
Apr 20, 2011 02:13 PM
billie
Oct 15, 2009 06:26 PM
charcoal600
Jul 29, 2007 08:42 PM
Hummin Cummins
Aug 7, 2005 06:46 PM
