Spicer # for front driveshaft joints
Old Nov 27, 2011 | 07:14 PM
freight train's Avatar
Hi, does anyone know the two spicer U-joints part numbers for the front drive shaft of our diesels? I know the two that are side by side in the flex joint are different than the one that goes on the front end yoke. I looked through all the stickies and found only the axle and rear driveshaft universal joint part numbers. But none for the front drive shafts.
Thank you
Old Nov 27, 2011 | 07:56 PM
ekk33's Avatar
http://www2.dana.com/expertforms/dek350.aspx
Here is where you can look them up right from dana spicer
Old Nov 28, 2011 | 01:28 PM
user name's Avatar
5-3147X for the two in the CV. At least on my 92. There were two options that is the larger cap size.
Old Nov 28, 2011 | 03:02 PM
Ok, thank you guys. They show two available for the front though. I assume are's takes the larger cap size? Time to get a mike out
Old Nov 28, 2011 | 03:54 PM
Guys I cannot locate my mike at this time. Can someone chime in. Is the dia of the caps on the front of the front drive shaft a:
1. 1.078'' Brg. cup dia.
(spicer #5-1306X)
or
2. 1.126'' Brg. cup dia.
(spicer #5-1309X)
The confusing thing is that my local Napa told me that the two in the cv joint are different than the front. If thats the case then by spicers website are trucks use the smaller front drive shaft u-joint??
Old Nov 28, 2011 | 08:11 PM
CaptainChrysler's Avatar
You will need to check yours and see which one you have, it can have either one. Find a socket that is the same O.D. as the cap,Then measure it with a tape.
Old Nov 28, 2011 | 09:10 PM
Capt are you sure it can have both? That would mean one trucks D60 front ends yoke will differ from others. I dont believe that is correct. I believe one is for a gas with a smaller 3500lb front end and the other is for the 4500lb front end. Thats my guess. I believe all diesels have the same. I just dont have a mike (Dad stuck it somewhere!). They are so close in size that my tape measure wont tell a difference.
Old Nov 29, 2011 | 09:55 AM
Yup, I'm sure. They always ask, and I have put both kinds in a CTD.
Old Nov 29, 2011 | 10:58 AM
My 91.5 took the small one, I got it at napa in the precision line. you need to take the driveshaft to napa with you and just hold the u joint up to it, It'll either be too wide to fit between the ears and the caps will be too big, or it'll be perfect.
2-Stroke
22
Jun 26, 2019 01:12 PM
BC847
Jul 30, 2013 08:48 PM
gsbrockman
Aug 15, 2011 01:34 PM
abc4yew
Oct 27, 2005 08:39 AM
JohnnyH
Jul 19, 2005 06:54 AM
