Front drive shaft grease fitting
Old Jun 9, 2010 | 03:46 PM
Bark's Avatar
Hmmmm. Maybe I could paint one on to make me feel better.
Old Jun 10, 2010 | 09:06 PM
Rod_Montana's Avatar
After struggling several times to get grease in to mine with the blunt end fitting, this time I was doing an Xfer case oil change and had the protection plate off (four bolts). Man, oh man, that was so much easier to grease the driveshaft. Got a good square straight shot and the grease went right in.
Old Jun 11, 2010 | 01:11 AM
AlK's Avatar
AlK
This is the needle that I use - it works.
Old Jun 11, 2010 | 05:11 AM
Hvytrkmech's Avatar
I use both of these, the B-5783 is designed to mate with the tapered surface of the zerk. I run my truck on extended drain oil changes, since the only time I grease it is when I am servicing it I just remove the shaft and grease it on a vice. To me the 5 minutes it takes me to remove it save a ton of aggravation.
http://www.alemite.com/catalog/detai..._guns_adapters
BanditoRam3500
Jul 16, 2010 03:42 PM
Rrloren
Oct 24, 2007 10:22 PM
EDWRDS
Jul 27, 2007 11:23 PM
Tiara3100
22
Feb 6, 2007 02:33 PM
Tiara3100
Feb 5, 2007 04:14 PM
