Front Drive Line Grease Fitting!
Old Jul 23, 2007 | 08:38 PM
EDWRDS's Avatar
Ok guys I've read the thread and seen the pictures where to grease the front drive line. My u-joints don't have any place to grease them? Is it possible they are a sealed unit! I even went and bought the needle to gease them! Any help I would appreciate It!
Old Jul 23, 2007 | 08:51 PM
Deesil's Avatar
Muted User
your stock u-joints do not have grease zerks, they are sealed. However, there is a ball and socket in the double cardan on the front shaft that is greasable. That's what the pictures are trying to help you locate. It has a "female" zerk. All you are greasing with that grease point is the ball and socket, not the whole driveline.
Old Jul 23, 2007 | 08:56 PM
EDWRDS's Avatar
I can't find my picture I saved can you find the pic for me my search doen't work? Drive shaft you mean front drive line correct?
Old Jul 23, 2007 | 09:04 PM
EDWRDS's Avatar
Ok foud the picture I know this is a stupid question is it the front or back of the drive line?
Old Jul 23, 2007 | 10:14 PM
Deesil's Avatar
Muted User
front
Old Jul 23, 2007 | 10:46 PM
AkitaSumo's Avatar
Huh? I would have said the front drive shaft at the transfer case...
Old Jul 24, 2007 | 10:08 AM
3ton1/4's Avatar
just had mine replaced at 76,000. from what i read that is pretty common.
Old Jul 24, 2007 | 01:27 PM
Foxborough's Avatar
It is real hard to see. I Put a floor jack and lifted the drivers front wheel and kicked the wheel around. With a flashlight I looked at the shaft. I must have spun the shaft 3 or four times before finally seeing the spot. It was hard to see because it has never been greased before. I assumed the dealer was servicing it .
Old Jul 25, 2007 | 08:10 AM
Skinner's Avatar
I did the same and then when I finally found it, I hit it with grease and made sure the zerk had a good covering on the outside of greese as well. THEN I took a bright red spray bomb and painted that area of the yoke so I can see it alot easier now.
Skinner.
Old Jul 25, 2007 | 09:09 AM
Danavilla's Avatar
Good idea Skinner! The next time I'm under the truck, the red paint (or maybe yellow) goes with me.
Dan
Old Jul 27, 2007 | 01:55 PM
No Plugs's Avatar
Skinner.
I went to the Dodge dearership to get the grease for this fitting. The sticker under the hood calls for a lithium base grease. It also has a mopar part number. I thought lithium based grease was white? The grease I bought from the dealership,"which matched the part number on the sticker" is green.
Anyway, I have 31k on my truck and have never greased this fitting. Before this picture, I could never find it. How do I know how much grease is enough?
Also, changing the gear lube in my axles. I bought Royal Purple 75W-140. Is R.P. a good choice?
Old Jul 27, 2007 | 09:47 PM
XLR8R's Avatar
Normally, you pump grease in until it begins to be forced past the seals of the bearing(s).
Old Jul 27, 2007 | 11:23 PM
woodrep's Avatar
No Plugs, I put Royal Purple in mine about 10,000 miles ago. I'm am satisfied with it so far, but I have a feeling that it might be a "fad". Royal Purple is a great lubricant which was designed around the racing sector which, as you know, they change their fluids after the Race... I'm going to keep it until my next change interval and then change to Amsoil 75W 110. Just my .02
BanditoRam3500
Jul 16, 2010 03:42 PM
psj12
18
Jun 11, 2010 05:11 AM
BKCBUILDER
24
Oct 8, 2007 09:13 PM
Tiara3100
22
Feb 6, 2007 02:33 PM
Tiara3100
Feb 5, 2007 04:14 PM
