front axle info
Old Oct 10, 2008 | 04:48 PM
Whistler477's Avatar
front axle info
I think my wheel bearings are going. Does anyone offer a non-sealed bearing assembly for these trucks, or do I have replace the whole spindle every time. I have 140000km on the truck, & that seems a little premature for wheel bearings to be wore out. Is this a common problem with this front axle? Its a 2003 2500 4x4.
Old Oct 10, 2008 | 08:07 PM
bighornram's Avatar
What are your symptoms that make you suspect the wheel bearings? I know ball joints don't seem to last long on these trucks...
Old Oct 10, 2008 | 08:18 PM
Yada's Avatar
mine went out at 227thousand km ,, it wasnt that loud when on its way out but ,, when it finally went i knew it ,, wheel was beginnning to lock up and thanx gawd I was in the town where my buddy fixes them. Thats why I dont like aggressive tires to much cant hear whats going on sometimes
Old Oct 11, 2008 | 07:57 AM
booman70's Avatar
You can do the free spin axle conversion kits then it uses cheaper common bearings
http://www.dynatrac.com/products_freespin_dodge.html
Old Oct 11, 2008 | 07:13 PM
billie's Avatar
If you stay with factory sealed, pull out the ABS sensor and add grease through the hole. Check once a year after that.
Cya
Old Oct 12, 2008 | 07:38 AM
Valv's Avatar
90,000 miles is a little premature. You cannot get separate bearings for it, you have to get the complete hub/bearing assembly, no way out, all the brands have them this way anymore.
I just replaced my left side and today will do my right side. Best price so far is $ 270 + shipping (each) OEM from a dealer online.
Advance Auto Parts has them for $ 270 also.
Old Oct 14, 2008 | 10:09 AM
I get a growling noise with a slight vibration, when I turn the wheel slightly to the right.
rustydeeretech
17
May 21, 2011 03:05 PM
2-Stroke
Mar 22, 2008 06:05 PM
donhov
Oct 12, 2007 11:44 AM
swampthang
Feb 14, 2007 09:14 PM
GO 4LO
Dec 26, 2002 12:31 PM
