Fixed fuel leak-why a line to back of head?
Old Feb 14, 2009 | 08:30 PM
CTD Hauler's Avatar
Had a drip at the bottom of the bellhousing about every 1/2 second. It took me quite a while with a VERY bright flashlight to find the source. There's a fuel line that runs to the back side of the cylinder head between the firewall and head. It's secured with a banjo bolt, mine was barely finger tight. Tightened her up good and no more leak.
Now for my question, What the heck is that line THERE for??
Thanks,
Ron
Old Feb 14, 2009 | 08:46 PM
bradler's Avatar
return line to fuel tank for extra fuel not used by injectors
Old Feb 14, 2009 | 09:24 PM
CTD Hauler's Avatar
Thank you.
Old Feb 15, 2009 | 08:06 PM
sallyman1's Avatar
but why would there be fuel there? wheres the passage from the injector.....the only passage to the injector is the tube itself. and if that dont leak where will the fuel go other than out the injector
Old Feb 16, 2009 | 12:57 AM
Haulin_in_Dixie's Avatar
there is a channel that runs across the injector bore and ends with the rear head line.
Old Feb 16, 2009 | 01:09 PM
dozer12216's Avatar
A drilled passage connects the low pressure area between injectors and head where the lubricating leak of injector goes.
Old Feb 16, 2009 | 07:13 PM
Isn't that what I said? At least i know what state I live in.
Old Feb 17, 2009 | 07:51 AM
Mr Bee's Avatar
This passage also alows any air to be circulated out of the system.
8Lug_hotrod
Apr 18, 2021 08:07 AM
GSP
Sep 24, 2008 03:52 PM
sgrooms
21
Apr 8, 2008 11:17 AM
JIT
Oct 19, 2007 11:32 AM
jwtuc
14
Mar 22, 2004 08:35 PM
