Fuel line to back of Head?
Old Oct 19, 2007 | 10:37 AM
JIT's Avatar
JIT
I noticed a fuel leak on my truck after putting in new injectors and it seems to be coming from a banjo bolt on the back of the head. What is this fuel line for? Im guessing it circulates fuel through the head to heat it but I dont see any lines coming out!
Thanks,
Josh
Old Oct 19, 2007 | 10:47 AM
Mike D's Avatar
It's the fuel return back to the tank.
Old Oct 19, 2007 | 10:51 AM
JIT's Avatar
JIT
Where is it getting fuel from? The injectors and supply lines look like a one way street... Sorry just trying to understand this thing.
Old Oct 19, 2007 | 11:15 AM
Shovelhead's Avatar
Administrator / Scooter Bum
There are two lines going into the side of the injection pump.
The rear-most one is the feed from the fuel filter, the other is the fuel return.
1. Fuel Transfer (Lift) Pump
1. Lift Pump
2. Fuel Return Line (to Fuel Tank)
3. Fuel Supply Line (Low Pressure, to Engine)
4. Fuel Heater
5. Water-in-Fuel (WIF) Sensor
6. Fuel FilterlWater Separator
7. IA T Sensor
8. Map (Boost) Sensor
9. Fuel Drain Manifold
10. CKP Sensor
11. CMP Sensor
12. Overflow Valve
13. Drain Valve
14. Fuel Pressure Test Potts
15. ECM
16. ECT Sensor
17. Fuel Injection Pump
18. Throttle Lever Bell Crank and Apps
19, High-Pressure Fuel Lines
20. Fuel Injectors
21. Fuel Heater Temperature Sensor (Thermostat)
22. Oil Pressure Sensor
23. Fuel Injector Connector
24. Drain Tube
25. Intake Manifold Air Heater/Elements
Old Oct 19, 2007 | 11:23 AM
JIT's Avatar
JIT
So there is fuel flowing through the head?
Old Oct 19, 2007 | 11:32 AM
Mike D's Avatar
Yes, but not much.
nrussell
Oct 29, 2009 07:30 PM
morkable
ABDTR #5
Mar 16, 2009 02:14 AM
CTD Hauler
Feb 17, 2009 07:51 AM
sallyman1
Feb 9, 2009 09:20 AM
GSP
Sep 24, 2008 03:52 PM
