fuel line in the back of the head
Old Mar 15, 2009 | 08:12 PM
morkable's Avatar
What does this do? Can I block it off? I was following the line and it seems to just go to the fuel filter cannister, which then goes to what used to be the rail (which is unhooked as I have a dual feed line on there) So from what I can see this is just taking up space. Am I right?
Kevin
Old Mar 15, 2009 | 08:21 PM
CTD Hauler's Avatar
Wrong. Mine was leaking from the banjo fitting last month. Just had to tighten it up, but found out in the process that it's the return line for the excess fuel from the injectors.
Old Mar 15, 2009 | 09:53 PM
morkable's Avatar
so where does it go? Where can I route it too?
Old Mar 15, 2009 | 10:11 PM
pind's Avatar
on the second gens, it routed to a T fitting in the return line to the tank. 1 line from the VP, and one from the back of the head, then back to tank.
Old Mar 15, 2009 | 10:17 PM
morkable's Avatar
Crap,, must be somewheres I can make it go,, I am not going to have the factory tank anymore
Old Mar 15, 2009 | 10:49 PM
pind's Avatar
how about returning it to the non-factory tank or return line.
I know thats a pretty big leap there, but its the best I can come up with right now....
Old Mar 15, 2009 | 10:51 PM
morkable's Avatar
Thats along ways back to bring it. I suppose it is allways an option, Im just hoping that there is another option
Old Mar 15, 2009 | 10:57 PM
StealthDiesel's Avatar
Hi Kevin,
As CTD Hauler posted, the fuel line from the back of the head is the injector excess fuel return line.
The CR fuel system routing is complex IMO.
There are actually 3 fuel returns. They all join together at the fuel filter cannister into the one return line back to the tank.
1. The injector fuel return line from the back of the head.
2. The rail excess pressure return line. From the pressure relief valve on top of the rail.
3. The excess fuel line return from the CP3.
All 3 are routed to the fuel filter cannister. A passage in the fuel filter cannister connects them.
A line from the fuel filter cannister returns to the fuel tank.
Do you have a service manual for your truck? The fuel system chapter is about a 100 pages to explain it all.
...Joe
Old Mar 15, 2009 | 11:02 PM
morkable's Avatar
Well I have the rail blocked off, I have the cp3 excess blocked off,, so do you think it would be bad to have the excess from the injectors blocked off?
Old Mar 15, 2009 | 11:09 PM
The rail pressure valve being capped & that return line removed is common.
I've never heard of the CP3 excess fuel return & the injector excess fuel return lines being blocked though.
I would be concerned with blocking those off, but this is the extent of my knowledge.
...Joe
Old Mar 15, 2009 | 11:25 PM
Mike Holmen's Avatar
The Guru
It could push fuel into the oil thru the injector orings. Kev, you have to have a return line, two Fass150 fuel pumps would have to move tons of fuel. Usually there is two lines. You running a fuel cell? There might be a return line available that way. You could just put in a bung into the tank just for that line if you get caught. I bet there more fuel bypassing the injectors than we would like to consider. Wasted/lost HP, just on connector tube pressure loss/drain.
Old Mar 16, 2009 | 02:14 AM
Tate's Avatar
On unit injectors, if you block the return line, you will hyrdo-lock the injectors. Even the CR injectors are actuated by solenoids, I'd imagine it would be similar. Plus, and leakage from the connector tubes is gonna go into that cavity in the head. Block it off, and it will blow past the o-rings in the injectors and contaminate your oil.
nrussell
Oct 29, 2009 07:30 PM
CTD Hauler
Feb 17, 2009 07:51 AM
sallyman1
Feb 9, 2009 09:20 AM
GSP
Sep 24, 2008 03:52 PM
JIT
Oct 19, 2007 11:32 AM
