aluminum bed liner worth anything?
Old Mar 14, 2009 | 01:31 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I have this full aluminum bedliner and I'm not sure if its worth anything now that you could get a line-X for less than half.I called and asked how much to build one including the floor mat...WoW....over $1,600.Was thinking about cutting up the liner and use it for boxing,if I ever decide to install stacks..Can't post pics....Got something wrong that Madhat is looking into..
Old Mar 14, 2009 | 01:35 PM
Festus's Avatar
Checker plate? Gauge?
Old Mar 14, 2009 | 01:39 PM
Its checker plate...I will get the calipers out and measure the thickness..
Old Mar 14, 2009 | 09:42 PM
It is 0.118 inchs or 3.00mm thick...also got my pic problem fixed..
Old Mar 14, 2009 | 10:50 PM
19Fury69's Avatar
Does it have a metal bottom or just the mat??
Old Mar 15, 2009 | 12:04 AM
Its a two piece rubber mat about 3/4 inch thick, and that thing is heavy..The liner sits on top of it.Have it in the truck till I figure out how to prevent things from sliding around.....That is one downfall of the line-x.
Old Mar 15, 2009 | 09:46 AM
Festus's Avatar
Sorry. I was hoping it was a bit heavier to use on another project. However, too light for my requirements.
Old Mar 15, 2009 | 01:25 PM
No problem...I will advertise it for sale and if it doesn't sell I will cut it up for my project...I priced out a sheet of 4x8,I almost had a heart attack how expensive aluminuim is....
Old Mar 16, 2009 | 02:34 AM
19Fury69's Avatar
How much ya want for it, and im still a little confused as to the bottom, it looks like the rubber goes into a chanel in the aluminum?? Does is have aluminum on the bottom and just have a lip on top to hold it down or is the rubber sitting on the original truck bed??
Thanks
Old Mar 16, 2009 | 09:38 AM
Hey Fred rock...The rubber mat goes on the bottom of the box and the alumuim liner sits on top of the mat.Then you bolt the liner through the liner and through the mat...If you notice the lip along the liner,thats where the bolts(lag bolts) go through...I think there is about 40 screw holes...As for price I have no idea yet..
chevyluvn
May 7, 2015 04:18 PM
darrylmueller
Mar 17, 2013 07:42 PM
CZSteve
Mar 8, 2011 08:11 PM
Clane
May 9, 2009 02:50 AM
04ctd
Feb 18, 2005 05:30 PM
