the wimpiest engine crane in the world
Old Mar 8, 2009 | 06:04 PM
morkable's Avatar
I have a brand new 2 ton engine hoist sitting in my garage, I went to go and lift the head on my truck today. And that fricken POS wont lift the head, I can move the head by hand, but the crane wont lift it..... ARRRGHH,, what next,, any ideas?
Kevin
Old Mar 8, 2009 | 06:32 PM
huck25's Avatar
If you can find some 2" pipe and a welder, build yourself an A frame hoist that you can take apart when your done. This way you can lift all kinds of things.
Old Mar 8, 2009 | 07:20 PM
Tate's Avatar
How cold is it in the garage? I know when my friends hoist got cold (-15 or better), the fluid was just too thick to refill the piston in the pump, have to wait about 15 seconds before you could give it another stroke. My princess junk hoist has been pretty good, though. His is also PA stuff.
Old Mar 8, 2009 | 07:43 PM
nickg's Avatar
Maybe no fluid in it or the valve is not tight, I have one from Costco, it works well just very slow to raise
Old Mar 8, 2009 | 07:45 PM
Mike Holmen's Avatar
The Guru
Is it the adjustable boom lenght? Mine took awhile to get to work right. You could check to see if there is hydralic fluid in the cylinder ram. Sometimes theres air that needs to be purged out of the system. Whats the rating on the cylinder?
Old Mar 8, 2009 | 08:06 PM
morkable's Avatar
Its warm in the garage, 70*. I cant seem to figure out how to check the fluid level on it. That is how it feels, as if it is low
Kevin
Old Mar 8, 2009 | 09:02 PM
Dr. Evil's Avatar
Are you sure the crane is the problem??
Old Mar 8, 2009 | 10:04 PM
morkable's Avatar
LOL,, thanks Shane... now,, how do you add fluid in these things? and what kind of fluid should I put in?
Old Mar 8, 2009 | 10:23 PM
Lil Dog's Avatar
Any hydraulic fluid type. heck even ATF works...
Old Mar 8, 2009 | 10:27 PM
morkable's Avatar
So,, this is going to sound stupid, where do you put it?
Old Mar 8, 2009 | 10:30 PM
Lil Dog's Avatar
Any of my bottle jacks have a rubber plug or screw with a washer in the body of the jack by the ram piston, probably about 1/2 way up.
Old Mar 8, 2009 | 10:35 PM
morkable's Avatar
ok,, yeah I have seen that,,, so do you just fill it up there till it starts coming out?
Old Mar 8, 2009 | 10:47 PM
Dr. Evil's Avatar
Fill to the bottom of the hole. Maybe there is air in the cylinder? I know on the hydraulic floorjacks there is a procedure to bleed the air out.
Old Mar 8, 2009 | 10:53 PM
Lil Dog's Avatar
Procedure bah!!! Push the ram down till it is all the way in. Pump it up about 1/2 travel and then release back down to all the way in. I do that a couple times until you can't hear/feel the bubbles in the fluid going out of the cylinder..
Old Mar 8, 2009 | 11:00 PM
morkable's Avatar
with the rubber plug out?
