Transmission throttle valve sticking
Old Feb 16, 2009 | 10:02 AM
zill's Avatar
My check engine light came on and I used my Diablo Predator to trouble shoot, it reads the Transmission throttle valve is stuck. When the truck shifts from 1st to 2nd it seems to take a very long time and shifts hard. Is the valve assembly accessible from the outside of the trans or inside and has anyone else had this same problem?
Old Feb 16, 2009 | 10:15 AM
dozer12216's Avatar
Would help to have little better indication of what you have. There was a change in 2005 on system. Have to pull pan to gain access. Much oil everywhere for first timer. Would suggest KD (2nd gear) band adjustment. Remember if threads do not protude beyond jamb nut, the band IS WORN OUT.
Old Feb 16, 2009 | 10:18 AM
zill's Avatar
05 4x4 112,000 miles last trans oil change was at 100,000 miles.
Old Feb 16, 2009 | 11:10 PM
no_6_oh_no's Avatar
The throttle valve they are referencing is the TV motor on the side of the trans that replaces the the TV cable. They go bad and stick then the trans doesn't shift correctly because th eTV pressure is not being set by the ECU.
Old Feb 17, 2009 | 09:20 AM
zill's Avatar
Thanks for the info.
pete97
Apr 2, 2006 09:58 PM
smokeyram
Nov 17, 2004 09:43 AM
finallydiesel
Jun 18, 2004 08:42 AM
dublr
Nov 21, 2003 08:30 PM
