Engine noise
Old Oct 9, 2008 | 09:02 PM
07ram's Avatar
Engine noise
It has been said retiming the fuel pump will stop the noisey clatter in the 07 5.9. Will this really work and will the darn thing get back out of time. The engine was very quiet when I bought it and now I have to shut it down to talk to someone standing next to it. Thanks, Don
Old Oct 10, 2008 | 12:05 AM
06RAM2500's Avatar
What all mods have you done to the truck? FYI, the CP3 doesn't time to the injectors, the ECM does that.
Old Oct 10, 2008 | 08:22 AM
07ram's Avatar
The only thing done to my truck is installing a Airaid intake filter. Pulls my 40' toyhauler great, but engine noise at idle is a real pain.
Old Oct 10, 2008 | 06:48 PM
steelblitzkrieg's Avatar
DTR Detective
Buy a Gasser or add some 2 stroke ashless.
Old Oct 10, 2008 | 08:07 PM
2007 5.9's Avatar
Here is a link on the 2-stroke topic...
works great and helps with noise...
https://www.dieseltruckresource.com/...d.php?t=212679
Old Oct 11, 2008 | 08:40 AM
TedT's Avatar
I haven't tried it but retiming the pump should help, but you may not hit the sweet spot on the first try. I works because any engine, gas or diesel speeds up and slows down slightly between power impulses. The injection pump has pistons in it that load the pump's driven gear intermitantly. The noise comes from this driven gear knocking against it's drive gear. The idea of retiming is to get these two gears to work together.
Incidently, differences in power impulses are how misfire detection works on engines that have the feature. Also the pump can't go out of time once you adjust it, as long as the gear is torqued properly.
Ted
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
richard
Jan 18, 2003 08:55 PM
Gregor
Dec 3, 2002 12:18 AM
rattle_rattle
Nov 24, 2002 08:10 PM
