electronic 4wd switch
Old Dec 20, 2005 | 06:08 PM
snowball's Avatar
I was backing my trailer up into its spot in 4lo and when I went to pull forward it stuck in 4lo. Tried shutting truck down but did not help. I am thinking it must be the solenoid that is shot, Any thoughts. Yes I did try the switch.
Old Dec 20, 2005 | 07:15 PM
gerry's Avatar
Not sure if this will work but maybe try putting the transfer case in netrual.. It is the little button you have to push with a paperclip or somthing .. then put it back to 2 hi...
Old Dec 20, 2005 | 07:39 PM
HorseHauler's Avatar
ugh i miss my manual transfer case, i hate electric ones... i hope this one doesn't crap out on me...
Old Dec 20, 2005 | 10:47 PM
Jeff in TD's Avatar
It shifts into and out of low range best if you are slightly rolling...
Do you get a blinking light when you try to shift?
Old Dec 21, 2005 | 06:29 AM
snowball's Avatar
Blinking 2wd lite
Old Dec 21, 2005 | 05:31 PM
snowball's Avatar
Put the truck in neutral and let roll back a little and it was all good. thanks
Old Dec 21, 2005 | 06:44 PM
Jeff in TD's Avatar
I think the blinking light indicates it is attempting to shift, but either the gears aren't lined up if you are trying to switch high or low range, or there is too much torque between the front and rear end if you are shifting out of 4x4 (or front and rear speeds are too different if trying to shift into 4x4).
Rolling slightly while shifting the range selector helps, and backing up helps disengage 4x4 if things are a bit bound up...
Old Dec 22, 2005 | 03:25 PM
PZM123's Avatar
Happened on my wife's.I took & tapped on the solenoid with the handle of a small hammer a few times & it did the trick. Talked to a wrench at the shop & he said that's the 1st thing they do!
1985cucv
32
May 19, 2010 03:12 PM
newfy
Jan 30, 2008 04:33 PM
mmurray
Jan 8, 2008 08:09 AM
973604x4
24
Jan 31, 2007 07:25 PM
myfirstdiesel
41
Feb 20, 2005 04:50 PM
