EGT range ?
Old Sep 7, 2008 | 08:36 AM
Valv's Avatar
EGT range ?
I have my probe installed pre-turbo and on rear side of manifold, to catch temp from rear cylinders. On good grades I hit 1300 deg easily, and can keep it there whether I have an empty flatbed or a mid size load (10k).
So far there hasn't been any problem, once I disconnected the Quad and had same EGT stock, but I would like to see other opinions.
Old Sep 7, 2008 | 08:46 AM
CTDinMT's Avatar
I don't hit those temps unloaded (more in the 1100 deg range) but loaded with my 12K toy hauler, on a steep grade I'll hit 1300 easily. That's running my Xzillaraider on setting 2. Stock is around 1200 in same conditions. My probe is between cyl 3 and 4 pre-turbo. Are you still running the stock muffler?
Old Sep 7, 2008 | 09:04 AM
Valv's Avatar
Yes, it is still the stock muffler only (no resonator) but...... pipe broke off before it on my way back to MN from NY state... I tell you what that was a LOUD 1200 miles trip !!!
EGT were same with it together or with it broken off.
I am sure I'm ok, I am just checking others just in case, thank you.
PS...and BTW I have a new exhaust coming.
Old Sep 9, 2008 | 12:30 PM
Adaminak's Avatar
I'm thinking 1300 is a little high with an empty truck, but it can be influenced by speed and throttle input too. Are you cruising up a long steep hill at 70-80mph and trying to maintain that speed? With an empty truck I can barely break 1100, no matter how hard I stand on it. With a loaded truck (around 19K gvw) I can hold 1300 all the way up a decent hill (60mph) and fighting headwinds I've seen 1450 for a few seconds before I let off the pedal and drop to 5th.
Has your truck always read that temp? Air filter clean and dry?
-Adam
Old Sep 9, 2008 | 01:54 PM
rip 112's Avatar
The rear cylinders stay hotter than the front ones, so good job mounting it. I can see 1300 at wot or pulling a load, these trucks are known to run high egts even stock, I think you're fine.
Old Sep 13, 2008 | 10:57 PM
BLACKBEAR's Avatar
1350 is tops I would not run it there very longe!!!
Old Sep 14, 2008 | 04:08 PM
rip 112's Avatar
While personally I agree with you, many won't. I've seen ppl post seeing 1500-1700* on their trucks. I would not pass 1400*.
Old Sep 14, 2008 | 04:36 PM
jrussell's Avatar
It's different for 03-04's and 04.5+. The newer trucks run hotter from the factory.
OrangeBlackHD
Jun 22, 2010 07:11 PM
Firstgenfanatic
Apr 10, 2008 12:24 PM
Mark Hodowanec
Mar 19, 2007 05:55 PM
jmccart
14
Nov 20, 2006 06:45 PM
pakman
Jan 10, 2006 11:47 PM
