Dying Clutch Fan?
Old Mar 6, 2011 | 04:55 PM
johndeer's Avatar
Dying Clutch Fan?
I have light oil dripping under the engine front, it's also sprayed around the front under-hood. I've twice had a momentary grinding sound like a failing bearing. I'm thinking its either the clutch fan or the water pump?
Thanks in advance for any advice. I'll be towing the 5'er home to Montana next week.
Rick
Old Mar 6, 2011 | 05:20 PM
Hvytrkmech's Avatar
Grab the fan and inspect it for play and freedom of movement. You should have some resistance when trying to spin it, however it should be a fluid type resistance with no hard or soft spots. If there is any play in the bearings then it is junk.
Old Mar 6, 2011 | 11:53 PM
johndeer's Avatar
Thanks
Tim, I appreciate your advice and will do that in the am.
Rick
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
