Dumping waste motor oil into the fuel tank...
Old May 21, 2008 | 05:39 PM
  #46
2500's Avatar
got down to 1/4 tank of mostly ATF. just dumped 10 gal ATC directly into tank. this was pumped directly from a automatic transmission flush machine. so all ATF has already been filtered.
running 90%+ ATF with no problems...
Old May 23, 2008 | 05:33 PM
  #47
SpeedyWS6's Avatar
The truck sat all last week, I was in my service truck. I don't like the way the truck smokes on cold start ups with all that oil in the tank. It looks like it would if the valve seals were leaking. So I topped off the tank with diesel and so far I am on the way to some really good fuel milage. I may go back to a heavy mix, cold start up was the only time I noticed any blue smoke.
Old May 23, 2008 | 10:30 PM
  #48
2500's Avatar
almost getting too heavy... dumped 5 gal ATF, 5 gal WMO into remaining 10 gal of 95% ATF in tank.
runs fine with this thicker mixture, but lightly smokes at idle.
97 12v really likes 100% ATF... no smoke at all except for a puff at startup.
took a 100 mile road trip this afternoon with no problems with this thicker mixture. cruised at 70-75 just like normal.
Old May 23, 2008 | 11:32 PM
  #49
matt ellerbee's Avatar
ive been watching this thread, and yesterday i put 1 1/2 qt of ATF and about a qt or two of virgin 10w30 to an almost empty tank,fuel light was on. no problems what so ever. i know it wasnt much, but im kinda weary to go dumping gallons on gallons in there just yet.
Old May 23, 2008 | 11:42 PM
  #50
2500's Avatar
unless you have a 12v.... I'd be real wary of dumping gallons too.
in fact this thread is one of the few places I've seen feedback for CR folks using anything but straight diesel.
note I've got a spare set of injectors and are prepared to replace P7100 and lift pump.
12v has a reputation for running on just about any oils. long before this $4 gal mess.
Old May 25, 2008 | 10:11 PM
  #51
2500's Avatar
OK... finally reached too heavy stage... 12v started not wanting to run at low speed cold. started up fine, but didn't want to idle smoothly.
once motor reached normal speeds, ran fine. you could tell motor didn't like the mixture. which was 100% waste oil consisting of 65% ATF / 35% waste motor oil.
12 valve ran fine on 100% AFT. throwing in much heavier motor oil started motor lightly smoking at lower rpms.
had 15 gal in tank of above mixture. put 5 gal of diesel to thin out. motor smoothed right out within minutes.
Old Jun 8, 2008 | 01:49 AM
  #52
jforce's Avatar
French fry particles are less damaging to the injectors and pumps than worn engine particles...and they smell better too
Old Jun 8, 2008 | 11:25 AM
  #53
banyon's Avatar
I think if the used oil is filltered to the right level(?) it`s a great idea. As long as you don`t go crazy with the amount per tank. What could a small amount hurt, like 5%-15% ?
Old Jun 11, 2008 | 11:55 AM
  #54
Sprinter17's Avatar
Muted User
I've run 5% used filtered oil in my 05,it ran fine, and it was a little quieter , even my wife ask me what I did to the truck it sounds different.
Old Jun 11, 2008 | 07:45 PM
  #55
TedT's Avatar
I've been running 5% also, much quieter.
Old Jun 11, 2008 | 09:14 PM
  #56
Rob0183's Avatar
Originally Posted by cdennyb
My oil is filtered and if I send in the sample and it still has all that contamination in it, why would I want to run it thru a $2,000+ injection pump and injectors. I don't care if diesel goes to $5/gal. the motor oil stays on the dusty dirt road.
Seems like hell froze over. Would you consider it now?
Old Jun 12, 2008 | 07:27 PM
  #57
wheatwhacker's Avatar
All our trucks at work got dipped for dyed fuel today.
I'm wondering what would have happened if I had ATF in my tank when thay pulled the sample?
Old Jun 14, 2008 | 08:05 PM
  #58
Joe N.'s Avatar
Does anyone have any experience using mineral oil? I have access to a limited supply of mineral oil and years ago we used to put any excess in the delivery driver's tanks but I don't know of anyone using mineral oil in a late model engine.
Old Aug 2, 2008 | 01:52 PM
  #59
Matt400's Avatar
Interesting thread, the ones doing it in a 3rd gen seem to be having no trouble at all.
