Drone
Old Aug 27, 2004 | 05:09 PM
NyukX3's Avatar
Angry Drone
I am wits end with my exhaust! I put a new S/S Magnaflow exhaust on and the drone was so bad that it viberated my teeth!
I then added an Aeroturbine muffler which helped a lot, but I still have a drone.
I am about ready to pull the whole thing off and start over
Any suggestions to fix my drone????
Old Aug 27, 2004 | 05:13 PM
Forrest Nearing's Avatar
sound deadener, stiff exhaust hangers, and welded connections. this allowed me to run 5" straight pipe.
Forrest
Old Aug 28, 2004 | 12:04 AM
NyukX3's Avatar
Any other suggestions???
Old Aug 28, 2004 | 12:56 AM
add another muffler or two
Old Aug 28, 2004 | 08:58 AM
Hannibal's Avatar
After the first time I drove around downtown between buildings with all four windows down, I like the sound and volume of the stock exhaust. It's not too quiet and has a nice authoritive tone bouncing off the sides of buildings. And it's quiet in the cab. I don't tolerate drone too well. I have head in a bucket syndrome alot and a drone gives me a migraine. Probably pollution in the Tampa Bay area...
A neighbor down the street has a 2nd gen dually with straight pipe. It sounds good but with his automatic it doesn't bring about the image of a big rig.
Old Aug 30, 2004 | 11:10 AM
NyukX3's Avatar
Any othe suggestons??
Old Aug 30, 2004 | 02:23 PM
jkitterman's Avatar
NyukX3
Any other questions?
How bad was the sound with the stock system? Attempting to put a sound dampening material like Dynamat may help on the passenger side. I know in my 2003 there seems to be a bid difference in the sound level from drivers and passenger perspective. You could also try a header wrap and at worst, cast iron sewer pipe!
Old Aug 30, 2004 | 10:26 PM
did you add any sound deadener? add any mass to the exhaust pipe? add a muffler or two?
trade it in on a Cadillac??
Old Aug 30, 2004 | 11:13 PM
dieselminded's Avatar
Originally posted by jkitterman
How bad was the sound with the stock system? Attempting to put a sound dampening material like Dynamat may help on the passenger side. I know in my 2003 there seems to be a bid difference in the sound level from drivers and passenger perspective. You could also try a header wrap and at worst, cast iron sewer pipe! [/B]
EAR PLUGS ??
My strait pipe groans a bit,,,, but I thought that was why I put the strait pipe on.
I like it .If I wanted a quite exh. I'd stayed stock.
put your eco junk back on that'll do it
Old Aug 31, 2004 | 09:32 AM
Delectric's Avatar
How about putting the old system back on and maybe just changing out the muffler? I took the cat off of mine and its sounds much better, and no drone or severe vibration.
Old Sep 2, 2004 | 02:01 AM
NyukX3's Avatar
Delectric......The factory exhaust got pitched at the muffler shop that did the new exhaust install.
My plan is to start over with a new exhaust (grrrr$$$$$) I have heard that the Banks system does not have a drone....any comments from my fellow diesel die-hards??
Old Sep 2, 2004 | 05:06 AM
it's probably going to sound pretty much the same...
DID YOU TRY ANY OF MY SUGGESTIONS? THEY DO WORK!!!
Lightman
16
Dec 21, 2003 08:36 PM
TurboPirate24v
Jul 25, 2003 10:23 AM
45
Jun 4, 2003 01:42 PM
cummins24
Jan 29, 2003 05:47 AM
