drained coolant- how much left?
Old May 6, 2007 | 03:31 PM
papaduck's Avatar
Does anyone know how much, if any, coolant is left in the system when drained?
I have always found that a quart or more is always left that can't be drained without dissasembly.
I have always drained and flushed with plenty of water, then added enough antifreeze based on the coolant capicity to get a 50/50 mix by then topping off with water.
I will need to use distilled water in the Cummins. The tap water here is very hard, lots of calcuim. I could buy enough distilled at wally world at $.65 a gallon for the flush, or I could save the run-off from the house airconditioner.
Old May 6, 2007 | 07:27 PM
dodgezilla04's Avatar
when i blew most of mine out, there wasnt much left to drain. i didnt flush it(because it violently flushed itself) you could use air to try and remove all of it.
mattzram
Oct 9, 2006 11:38 AM
Warlord
Jun 2, 2006 05:13 PM
fitzydog
Apr 23, 2005 07:42 PM
fitzydog
Apr 21, 2005 09:04 PM
mr T
Jan 31, 2005 06:16 PM
