Do you run with your OVERDRIVE on in the City?
Old Jun 4, 2004 | 09:04 AM
doitl8r's Avatar
Just wondering if you guys run with your overdrive ON or OFF when driving in city traffic?
I find I get alot of "clucks" when in stop and go traffic.
Frist off I hope this is normal!
Second - turning the OD off seems to help.
Cheers
2003, LB, CTD, 4x4,
Old Jun 4, 2004 | 09:28 AM
Peterbilt's Avatar
Yes, I use mine alot. When I'm in traffic or moving under 45 (or so depending) I turn OD off.
Pete
Old Jun 4, 2004 | 12:50 PM
BigBlue's Avatar
I leave mine turned off under 60 and will actually cruise at 55mph in 3rd. Dropping it in OD bogs the engine to bad.
Old Jun 4, 2004 | 02:57 PM
chrismez's Avatar
I always drive with the OD on even in LA traffic. The noises you hear might be what I experienced with my truck when I first bought it. When going up a hill under moderate throttle my truck would make this "chuffing" sound as it shifted into OD. At first I could not figure out what it was, but I removed the silencer ring from the turbo and have never had the sound again. The sound I heard was blow back though the turbo when the RPM's dropped suddenly...This could be what you are hearing.....
Old Jun 4, 2004 | 03:05 PM
handymantim's Avatar
I leave the OD button alone and let the computer in the truck, which is smarter than me, figure out when to shift. I pull a 5000# utility trailer around all day and it doesn't hunt for gears so I don't bother.
Old Jun 4, 2004 | 03:19 PM
Vaughn MacKenzie's Avatar
Question: "DO you ever use Overdrive in the City?"
Answer: "No. I never go above 5th gear."
Vaughn
Old Jun 4, 2004 | 07:29 PM
Lsufan78's Avatar
is the overdrive button ya'll are referring to the same thing as the tow/haul?? i had an o/d button on my 96' gasser, but not on this truck??
later, dustin
Old Jun 4, 2004 | 09:32 PM
nick_domingo's Avatar
i never touch the od
Old Jun 7, 2004 | 04:31 PM
murray's Avatar
All the time. Otherwise, I loose about 2 miles to the gallon.
Alan
Old Jun 7, 2004 | 04:40 PM
Yes, the Tow/Haul button is the same thing as the O/D button.
Yes, I leave it in O/D all the time. This great forum taught me that if it starts hunting for a gear it's time to hit the Tow/Haul button and disable overdrive. My truck hasn't hunted for O/D yet.
Old Jun 7, 2004 | 05:23 PM
mymaur's Avatar
Re: Do you run with your OVERDRIVE on in the City?
Cheers
2003, LB, CTD, 4x4,
I leave it on.
Old Jun 9, 2004 | 07:20 AM
hfd376's Avatar
Mine stays on all the time.
Doug
Jeff5886
Jul 12, 2009 08:11 PM
dodgestang
20
Aug 6, 2006 12:41 PM
Dodgezilla
15
Oct 2, 2004 10:06 AM
MYTRNx3
Apr 29, 2004 12:56 AM
