Death Wooble.. Help Please!
Old Jun 12, 2007 | 09:47 PM
vj_M's Avatar
I have just installed 2" blocks in the front of my 1 ton with Sky Jacker shocks and we went to the mall in edmonton alberta today and we near piled er up doin about 110 130 somewhere in that range this was the Crazyest feeling ever.. DEATH WOOBLE SAYS IT ALL !!! What causes this? i just got an aliment done with 5-6 Caster like some of the forms sayed with 0 toe in, but this was rediculious!!!!!!
i have a big bore stablilzer from Sky Jacker in the front as well..
all the streering rods are in "A" ok shape..
what do i do.?
HELP PLEASE
VJ
Old Jun 12, 2007 | 10:22 PM
tbarbee1's Avatar
Hows your steering stabilizer shock?
Old Jun 12, 2007 | 10:29 PM
vj_M's Avatar
a brandnew skyjacker single
Old Jun 12, 2007 | 10:39 PM
firemansdiesel's Avatar
Usually when you put a lift in the front. You should upgrade your control arms. Usually that will cure for most part the death wobble.
Old Jun 12, 2007 | 10:41 PM
Luvnacumns's Avatar
What tires??
Old Jun 12, 2007 | 11:04 PM
vj_M's Avatar
pro comp mud trein 35 12.50 17 they are wore a little like about 1/4 left. they are Scaluped if that makes any sence to ya.. wore un evenly.
Old Jun 12, 2007 | 11:08 PM
vj_M's Avatar
but it never did that before i put the lift in.... with them tires wore like that.
Old Jun 12, 2007 | 11:19 PM
vj_M's Avatar
What if i put 4 shocks on the front axle 2 on each side and dual front steering sabilziers..?
Old Jun 12, 2007 | 11:49 PM
Luvnacumns's Avatar
Get a Theuren steering stabilizer.. Another note when you did the leveling kit did you mark your springs and put them back in in the same exact spot?? Dual shocks arent' goona solve the problem it's in the steering components
Old Jun 13, 2007 | 02:21 AM
vj_M's Avatar
No, I didn't, but i thought of it after i took them out..would that make a difference.?
I know that this could be a posible problem, however, I have a bad universial in the front diff on the pass side and the bearing in the diff is sloopy... Could this be a majure problem, its gettin fixed on friday so i won't know if that was it till then.. But it never had the wooble until i put the lift in the other day.
any suggestions..????
Old Jun 13, 2007 | 02:29 AM
vj_M's Avatar
I don't know if this helps but i will put up the Caster angles and TOe in
I need help with this ASAP PlEASE!!!
front toe LEFT Right
ACTUAL ACTUAL
-0.4 -0.0
5.2 5.6
0.12 0.08
CAMBER CASTER
LEFT RIGHT
5.2 5.6
Old Jun 13, 2007 | 11:17 AM
vj_M's Avatar
Anyone..? if not iam goin to take them things out there nothing but a hazzle! I called top gun custumz today where i got them and they said to replace all the steering components maybe even a drop pitman arm and drop trac bar braket
Old Jun 13, 2007 | 11:39 AM
MEGA COP's Avatar
I don't have my alginment sheet in front of me here at work but those castor #'s seem a bit low. I'll have to check my sheet out tonight when I get home and compair to be sure though.
Old Jun 13, 2007 | 02:07 PM
bsj04's Avatar
specs on front alignment
caster
tol. 4.0* to 5.4* mine set at 5.0* and 5.2*
camber
tol. -0.3* to 0.8* mine at 0* and -0.2
toe
tol. 0* to 0.10* mine at 0.5* and 0.5*
mine has been fine with stock shocks so far...
to me it looks like your toe is a little on the max side and if thats not it maybe its the tires. i know it didnt do it before but since the angle of the track bar and steering drag link has increased it moves more from side to side when you hit a bump. that mixed with bad (worn unevenly) mud tires only makes it worse.
try gettin you toe off the max side and then maybe try some different tires that are in good shape.
Old Jun 13, 2007 | 03:29 PM
CrashCade's Avatar
I would mess with the caster a little bit till you find what is right for your truck. That, and the track bar needs to be lengthened. You should be able to make it work by just messing with the caster anyways...
