Dealer says I need a lift pump
Old Mar 2, 2005 | 07:25 PM
Ram_in_Texas's Avatar
Greetings.
I took my 2004.5 CTD 4x4 QC 6spd in for service because it started to miss at startup after sitting over night with lots of white smoke coming out the exhaust. It was low on power while pulling an 8k load and putting out lots of smoke when pulling grades. I figured it would be an injecter, but the dealer called and said it was a lift pump. I'm confused on how a lift pump can cause a problem at idle? At this point the truck is totally stock.
Old Mar 2, 2005 | 07:42 PM
gsbrockman's Avatar
What method did they use to determine it was bad......fuel pressure or volume ? I'm by far no expert, but I'd suspect you have one or more injectors causing your problem more so than a lift pump.
Greg
Old Mar 2, 2005 | 07:54 PM
I have no idea what method they used to determine the failure. I talked to the service writer, not the diesel technician. Another thing was that fuel economy had dropped some while towing. Again how would a lift pump cause this? I'll let the dealer replace the lift pump, but after that if the engine is still running like crap I hope they start looking at the injectors.
Old Mar 2, 2005 | 09:13 PM
bigblock2stroke's Avatar
Keep on them RaminTexas.
You're on the right track. There have been lots of threads on this.
Old Mar 18, 2005 | 02:45 PM
Well I got the truck back after about a week. Apparently lift pumps were on back order so I had to wait for one to come in. They replaced the lift pump but the truck was still acting up. So I took it back to the dealer on Tuesday so it would sit overnight for them to see the problem. Called them today and they are still looking at it. Apparently STAR is asking for a whole bunch of tests and printouts. The good thing is that the service writer agrees that there is definately something wrong - he could have said the old line of BS that all diesels run like this on startup." I just hope I don't get the DC company line of too much idle time. The truck has a build date 0f 3/04 and I bought it in late November. Since then I have put over 15000 miles on it and half of that is towing a 10k load. If there was any excess idle time it happened on the dealer lot. The funny thing is that the truck ran great for the first 12k miles. I've used PS & Stanadyne PF since it was new and I changed the fuel and air filters right after this problem started
Reggie
Old Mar 18, 2005 | 03:13 PM
hoser's Avatar
turn your key on and off 3 times...any codes pop up in the odometer?
Old Mar 18, 2005 | 03:19 PM
I honestly did not check. The first time I took it in the dealer said there was a code for low lift pump voltage, that's why it was replaced. The check engine light never came on for this problem. I think it is an injector problem, but I have to convince the dealer/technician and they have to get STAR to approve it. Kinda stupid but it's what we have to deal with.
Old Mar 18, 2005 | 03:35 PM
hoser's Avatar
Ask them to do a cylinder kill test(shuts off injectors one at a time) while its missing...the cly that doesnt change the miss as much is the injector at fault..do you have a longer than normal crank time ? Plus get them to check inj pump pressure at full load..should be upwards of 20000psi + , if lower , it will prob be the pressure relief valve opening at a lower pressure causing low power.
Old Mar 18, 2005 | 04:30 PM
I did ask them to do an injector kill test when I dropped the truck off. I just got off the phone with the service writer and he said that they are going to replace one injector - but there are none to be found on the west where I currently reside. So best case will be mid next week.
buddy26
19
Feb 16, 2008 01:27 PM
Jerkyman
69
Jan 30, 2008 08:28 PM
BUSAHAULER
16
Feb 20, 2007 06:13 PM
doomgaze
Dec 18, 2006 09:01 AM
PsRumors
Mar 3, 2006 05:45 PM
