Dead Pedal
Old May 14, 2012 | 07:50 PM
steelman's Avatar
Dead Pedal
I have been lurking for a while but this is my first post. I know there are a bunch of dead pedal threads, but I have done quite a bit of searching but haven't found a solution to my issue.
I have on '03 stock expect for a Quadzilla. I am having intermittent dead pedal issues, and have had no codes ever. It usually happens when I am cruising 60-70mph on the highway. When I slow down to around 30mph or put it in neutral the engine will die. Once I pull over it usually starts right back up, but occasionally I have to crack it a few times. Even though I never got any codes I figured it was the APPS and replaced it with a Timbo unit and cleaned all the grounds I could find. It had no effect. Then I replaced the lift pump with Geno's filter mounted unit and it seemed to go away for 6-8 months. Well now it is back. I installed a fuel pressure light, comes on with less than 5psi, with the pressure switch mounted it at the CP3. I watched it and it didn't engage until the light until the engine died, so I figure the lift pump isn't the issue.
I am tired of throwing parts at it, anybody have any ideas.
Old May 15, 2012 | 09:24 AM
jhenson's Avatar
Check your FCA and verify that it's functional.
Old May 15, 2012 | 09:26 AM
jhenson's Avatar
Another thing....set truck back to stock and remove Quad just to see if problem still persists.
Old May 15, 2012 | 06:23 PM
steelman's Avatar
Any way to do that other than the rattle test?
Old May 15, 2012 | 08:04 PM
Spooler's Avatar
Run some ashless 2-stroke oil in it and see if it goes away.
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
BillH
Apr 26, 2004 10:09 PM
mymaur
Jan 26, 2004 11:31 AM
