Dead Pedal
Old Apr 26, 2004 | 11:20 AM
BillH's Avatar
Dead Pedal
Was returning from Tennessee yesterday, pulled off E-Way for a bite and truck would idle about 1100 RPM I then went down the road about 80 miles and truck just quit, would idle only. Shut it off and restarted a couple times and all was ok although the engine light stayed on.
Pulled codes this morning and only showed P PCU any meaning to this? What to do next? Truck has 42600 miles and all gauges, including FP register normal.
Thanks
Bill
Old Apr 26, 2004 | 11:44 AM
dodgediesel4x4's Avatar
Please fill in your signature to see can help you to the fullest. If you have a 24 valve then try this:
I'd reset the apps just to see if that helps:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
How long has it been since you replaced your fuel filter? I'd also give that a try.
P PCU doesn't mean anything. It just tells you that a scan was done. Go to Auto Zone and have them scan your truck, they can pull codes that we can't get.
I'm guessing it could also be your apps. Try a search and see if you can find similar symptoms. I'm sure others will chime in to help.
Good luck,
Hunter
Old Apr 26, 2004 | 12:27 PM
BillH's Avatar
Truck is a 2002 6 speed and changed fuel filter at 41000 miles and new L/P about same time. Also, bone stock.
Old Apr 26, 2004 | 12:58 PM
BillH's Avatar
Thanks, I will reset the apps tonight and see what happens.
Bill
Old Apr 26, 2004 | 10:09 PM
J BODY's Avatar
I would have the codes retrieved first.....but thats just me.
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
cmckinney
Aug 2, 2004 06:01 PM
mymaur
Jan 26, 2004 11:31 AM
