dana or american axle
Old Dec 16, 2010 | 03:08 PM
txbovine's Avatar
Hello , looking for input on my rear differential. the pinion shaft snapped on my 04, 4x4 it has a 11.5 American axle in it . who makes a better rear end dana or aam . I have always heard that the dana 60 was a very good rear end , I also would like to change the ratio from 3.73 to 3.54.
options: a) regear orginal axle providing differential housing is not damaged.
b) find dana rear end with 3.54 gears already in it.
Put your 2 cents in need to find a clear direction to go .
thank txbovine
Old Dec 16, 2010 | 03:21 PM
MikeyB's Avatar
I've heard that AAM is the stronger of the two. Plus AAM uses gear lockers and not clutch packs like the Dana.
You won't find a 3.55 for the AAM 11.5" but they do offer a 3.42.
Or stick with 3.73 and install larger 285/70/17's tires. That will get you close to 3.55.
MikeyB
Old Dec 16, 2010 | 03:54 PM
DevilzTower's Avatar
you'll eat a D60 alive with the torque and weight of these trucks ... the AAM 11.5" is much stronger.
Old Dec 16, 2010 | 04:07 PM
Hodge's Avatar
The earlier 3/4 tons used Dana 70's in the rear, not 60's.
The AAM and the Dana both are strong axles- you should figure out why yours broke, before moving up to a bigger axle.
Old Dec 16, 2010 | 04:36 PM
bnold's Avatar
6spds got a D80
Old Dec 16, 2010 | 05:20 PM
rockcrawler304's Avatar
I would avoid a D60. Like said above, first find out why yours broke and then possibly fix that and keep the axle. If you really want a new one, look for a D80 but an easier swap would be another AAM if yours is not fixable.
Old Dec 16, 2010 | 05:32 PM
txbovine's Avatar
I'm fairly sure it was that 40ft gravel truck that t-bone me . broke both springs emergancy cable , both shocks had to cut the rear wheel off . I set it up and checked for damage replaced all broken parts ran fine for about 500 mi , when pinion shaft snapped lucky i had 4 wheel drive droped rear shaft and made it home.
Old Dec 16, 2010 | 05:38 PM
Andy505's Avatar
Originally Posted by bnold
6spds got a D80
5 speeds too. All 2nd Gens with Cummins/Manual combos have a D80 rear.
All 1 tons regardless of drive train combo or engine have D80.
Old Dec 16, 2010 | 05:42 PM
bnold's Avatar
Good enough for me!
Bobcat698
Nov 9, 2005 02:38 PM
buford
17
Mar 11, 2005 09:29 PM
OT-OF-Here
Jul 8, 2004 09:57 AM
Teddroe
Feb 27, 2004 02:37 PM
spots
18
Jan 29, 2003 07:57 PM
