American Axle Vs Dana 80
Old Nov 8, 2005 | 05:00 PM
Bobcat698's Avatar
I'm curious, I'm sure someday there will be a day when I make enough power to destroy my Dana 70, at which point I need to put a Dana 80 in.
What are your thoughs on the new American Axles under the 3rd gens vs the Dana 80s in the manual-cummins equipped 94-2002 trucks?
Are there different sized American axles under the new Dodge or are the 2500 & 3500 SRWs the same as the 3500 DRW?
Old Nov 8, 2005 | 06:49 PM
G1625S's Avatar
not sure on different flavors, but the aftermarket is already tooled up for the 80 whereas you may be waiting around a good while if you want to upgrade the AAM, FWIW
Old Nov 8, 2005 | 07:17 PM
Greguw's Avatar
Re : Rears
I am new to to this fourm ...I am strating all over building anew truck ...I have a f-350 with about 80 grand in it ...and it's just siting in my driveway waiting for the tittle to come back before I can un load it ...that truck has the 22.5 alcoas ... with the big tires ...
Now I have a little dodge I just picked up to get my feet wet ...LOL
I do know rears , I would go with the 80 , lack of available parts would be the reason I would steer away from AAM .
I was building a few of those eaton rears ... there like bullet proof and you can even do a two speed rear ... just not in four wheel drive ... that would be a mess.
You should really check out Danatrac ... they can build a rear !
Later
Greg
Old Nov 8, 2005 | 11:19 PM
displacedtexan's Avatar
I also agre with the 80, as strong, and a LOT more aftermarket support. So you can build it even stronger...
Old Nov 9, 2005 | 08:46 AM
Eskimo's Avatar
Aftermarket support for a 80.. phooey! No limited slips diffs available. I want a gear-driven limited slip, none of those clutch pack thingys.
Old Nov 9, 2005 | 08:59 AM
TxDiesel007's Avatar
ARB?
Or a detroit locker..... for ur Dana 80, Powertrax have a good reputation? The only reason i aint gotten a locker (yet) is the funds for it... I sure wouldnt mind an ARB though.....
Tx
Old Nov 9, 2005 | 02:38 PM
ridofpwrstroke's Avatar
Just put in my arb for my 80 and love it. If you are putting in an arb, get the dana 70HD w/35spline shafts. The dana 80 arb will not work unless you have a thick gearset that no one makes as we speak, but are going to release in the next month or so. 800 bucks will get you rolling.
txbovine
Dec 16, 2010 05:42 PM
buford
17
Mar 11, 2005 09:29 PM
OT-OF-Here
Jul 8, 2004 09:57 AM
Teddroe
Feb 27, 2004 02:37 PM
spots
18
Jan 29, 2003 07:57 PM
