Cruse control problem
Old Jun 19, 2011 | 01:53 PM
jpajax's Avatar
Well I guess I spoke to soon that had no problem. It just started that when I try to turn the cruse on the light on dash will come on then suddenly go off and cruse control doesn't work. Any suggestion on what to check?
Old Jun 19, 2011 | 04:01 PM
Spooler's Avatar
Vaccum lines from the vaccum pump by the passenger side battery. The line will run to the dashpot under the drivers side battery. If you have had a leak for a while you may have burned up your pump.
Old Jun 19, 2011 | 04:03 PM
brightrevenue's Avatar
I would have the PCM checked out. My PCM has a problem & I'm waiting for a new one. It's only been 9 months, but Chrysler doesn't really care. The other thing you may want to check is the speedometer connection.
Old Jun 19, 2011 | 06:52 PM
jpajax's Avatar
Pump working ok pulled the line off and it came on plug it up built up vacuum went off. Could not find a fuse marked cruse control but I guess if the light comes on would the fuse be bad. Is there a wire that goes to the back of speedometer?
oldblues
Aug 4, 2007 11:17 PM
Evertight
Feb 19, 2007 11:57 PM
alborada
Jul 22, 2006 12:20 AM
xyzer
Apr 23, 2005 01:06 AM
