Cruise control.
Old May 27, 2013 | 12:19 PM
yuma guy's Avatar
Question Cruise control.
I have read the previous threads and got some mixed comments .
I have a 2006 Dodge 2500 with 5.9 L . it has a GT tuner and cat back exhaust, turbo has some work intake.nothing to wild.
i installed cruise control switches. the cruise light comes on . but it does not work. i bought the switches new. Any advice or good direction for trouble shooting
Old May 27, 2013 | 01:32 PM
madhat's Avatar
Administrator/Jarhead
I take it that cruise was not standard in the vehicle? Is it a ST model?
Old May 27, 2013 | 06:23 PM
yuma guy's Avatar
you are correct. it did not come with truck and is an ST
Old May 27, 2013 | 09:23 PM
madhat's Avatar
So, you just installed the switches in the steering wheel and that was it?
I'd have to do some research, but I'm wondering if some other stuff wasn't needed to make that happen.
Yuma, huh? I just left there. Sorry for you, man.
Old May 27, 2013 | 09:31 PM
yuma guy's Avatar
Yea just threw in the Switches, i read post where some said yea put switches in and it worked.that was not not the case for me, but the cruise light comes on when i turn on the cruise but that's it... It is starting to warm up. But i will be moving to Texas SOON. Yuma has No smog Or inspection... not sure what i will do when i get to Texas i will surly Fail Visual....for some reason , i think i am missing some parts off my Exhaust? i am not sure.
Old May 28, 2013 | 05:00 PM
yuma guy's Avatar
Cruise working.
I had to go move a Car so i went to U haul to pick up a car hauler. he told me my Brake lights were out. i checked some things found the brake switch was not working. installed new one, and just for grinns tried cruise control it and it worked. so if the brake switch it out your Cruise will NOT work. makes sence... Thanks for your Quick Response.
Old May 28, 2013 | 07:42 PM
rockcrawler304's Avatar
Glad it is working now!!
And when you move here to Texas you will most likely have no issues with the state inspection. Most places will not look under your truck because it is a safety only inspection. If windows are tinted make sure it's not darker than 25%. If it is just roll down all the windows, I hear some will over look them!
Old May 28, 2013 | 10:46 PM
Spooler's Avatar
Yeap, it won't work if you brake light switch is out. Dodge uses the same switch to cancel the cruise when the brakes are depressed.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
