Cruise Control
Old Apr 11, 2010 | 04:13 PM
gtstrkd's Avatar
Cruise Control
I havin trouble with my cruise control and need some help. The cruise works fine after you set it but when extra go is needed it kicks itself out and won't work again until key is turned on and off. What gives have a 600 mile trip ahead of me and need some help quick
Old Apr 11, 2010 | 08:01 PM
Spooler's Avatar
You have a vaccum leak. Check the line from the vaccum pump (behind passenger battery) to the cruise dashpot under the drivers side battery. The plastic line has been noted for having a hole rubbed in it in spots.
Old Apr 12, 2010 | 08:30 AM
gtstrkd's Avatar
I fixed the hose is there anyway to check the pump itself to see if its still working or not
Old Apr 12, 2010 | 08:34 AM
Spooler's Avatar
Was it leaking before? If so, the pump may be on the way out. So, is this the second time you have had issues? You normaly will hear the pump run at the turn on of the key, if it runs continuously, you have an issue. (bad pump or another leak)
Old Apr 12, 2010 | 09:38 AM
gtstrkd's Avatar
The cruise started acting up about a month ago I just got around to lookin at it yesterday found the hose had rubbed through fixed it and still only works until more pedal is needed then cuts off
Old Apr 12, 2010 | 10:13 AM
Spooler's Avatar
Do you hear the pump running on the first key on of the truck in the morning? Does the pump run all the time? You may have a bad pump. Normally if you have a leak and don't get it fixed quickly the pump will wear itself out.
Old Apr 12, 2010 | 12:28 PM
nvr-enuf's Avatar
I do not want to jack your thread. My vacuum pump runs 100% at key on, I do not know when the engine is running. My cruize worked once yesterday then nothing. I checked by the pump, did not find any leaks. I did notice the air linet that goes into the truck- about the middle of the firewall between the driver and passenger. I guess the only way to diagnose the problem is to see to seperate the T and try to pull a vacuum with a brake bleeder. I would assume if I hook up the brake bleeder to the pump that it should tell me if the pump has taken a crap. Any other suggestions would be appreciated. The other day I did remove the drivers side battery - maybe a line came apart and I did not notice it.
Old Apr 12, 2010 | 12:34 PM
gtstrkd's Avatar
I will listen for the pump when I get around the truck I appreciate all the help
Old Apr 12, 2010 | 03:22 PM
Spooler's Avatar
Yeap, you have a leak and the cruise dashpot is under the drivers side battery.
Old Apr 23, 2010 | 06:24 PM
Kilroy's Avatar
I found this thread because I also have a cruise control not working. With information found here I've discovered my vacuum pump is not working. First it is not running with the key on or with the motor running. Checked there is power to the pump, and after I took it off I connected power to the pump and it still does not run.
Went to dealer and they want $256 for new one, sounds nuts. I'm looking for a cheaper place to buy. Is it worth looking at a used one?
Old Apr 24, 2010 | 07:23 AM
Spooler's Avatar
Check online. I don't remember the IP. I think it is moparparts.com for good prices.
Old Apr 24, 2010 | 07:34 AM
tlloyd's Avatar
Its "moparonlineparts".com They have good prices and are always lower than local dealers,even when you calculate the frieght.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
