cracked trans casing what to do?
Old Nov 24, 2008 | 02:49 AM
Tim Holt's Avatar
If you can get hold of a Sonnax parts book from your local REPUTABLE trans shop, Sonnax makes a cooler line fitting that will eliminate your problem. The fitting extends past the crack and seals in the bottom of the thread bore.
This crack is a common problem with the RE/RH cases because of the large bore and thin casting in that area. Just pull your fitting and install the Sonnax fitting, your done.
I will try to get that part number by this evening.
Old Nov 24, 2008 | 03:10 AM
itr.#1446's Avatar
Wow thats good to hear, i still wanna get a new trans soon but atleast i will be able to drive my truck.
Old Nov 24, 2008 | 03:21 AM
itr.#1446's Avatar
i think i found it!!!!!! is this it ? i never would of known about this if it wasn't for your post thank you very very much
http://www.sonnax.com/part_summary.php?id=3465&pl=3
Old Nov 24, 2008 | 03:39 AM
itr.#1446's Avatar
I saw your a very experienced trans builder i have a question for you. I just installed a transgo kit, wish i knew about sonnax i saw they sell a kit but my shift indicator is off by a gear so when i go in park the cluster says reverse. So how do i adjust this? Do i adjust the line thing under the steering wheel? I played with one of them two ago when taking my friends totalled truck apart.
When i went for a ride it didnt drive well either i had to give it alot of gas for it to go, i am not sure yet if it was low on fluid since it was leaking alot of if i installed the kit wrong. I drilled two holes for firmer shifts and enlarged the one hole it says for the plowing which i do. Any ideas on what may be wrong? One thing i thought i may have done wrong is there suppose to be a spring on each side of the accumulator or just the one fat one? I didnt when putting it together it said to replace the fat one and said reuse the other long one but i didnt have one and it said some trans dont have 2.
Old Nov 24, 2008 | 06:23 AM
Checkmate's Avatar
Hmmm good post. Nice to learn new things.
Old Nov 24, 2008 | 10:57 PM
Prodart440's Avatar
That is the correct part. Sonnax makes them for a reason.
Old Nov 25, 2008 | 07:43 AM
Fisherguy's Avatar
WOW, that sucks, hope you get'r fixed.
John Faughn
Jul 15, 2011 09:26 AM
klx650a2
Apr 20, 2009 05:25 PM
autotecsvc
16
Mar 7, 2006 07:17 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
Dodgezilla
Nov 24, 2002 07:31 AM
