cracked trans casing what to do?
Old Nov 23, 2008 | 06:19 PM
itr.#1446's Avatar
I was doing a fluid exchange on my truck and when i put the line back into the case it made a big crack the goes all the way down to where the tail end gasket is. I cant tell how long the crack goes because it almost seems like fluid is coming from the gasket area to where the tail bolts on. I am so ****** right now, i am not sure what happened if it was because its so cold out or i over tightened it but i need some opinions on what to do. Can this be welded or even trusted if i did that or should i just save up and buy a new trans like hts, georend or suncoast? I figured that would make more sense then just buying a new casing and doing all the work.
Old Nov 23, 2008 | 06:45 PM
YOUNG GUNS15's Avatar
convert to a manual
Old Nov 23, 2008 | 06:50 PM
itr.#1446's Avatar
i didn't think of that lol how much would it cost to do a auto manual swap for parts? right now i wish i would have bought a manual to begin with
Old Nov 23, 2008 | 06:52 PM
Checkmate's Avatar
wow. It IS possible to weld.....BUT .
Old Nov 23, 2008 | 06:53 PM
Checkmate's Avatar
Too much. Lot more involved than just swapping.
Old Nov 23, 2008 | 06:54 PM
itr.#1446's Avatar
Yeah i know tons of work that is pointless haha i would have to pull the tail end off to see if cracked all the way thru and then hope it still wouldn't leak. If it did afterwords i would cry honestly...
I know it what swapping usually consists of ecu all the other stuff too.
Old Nov 23, 2008 | 09:11 PM
itr.#1446's Avatar
here is a pic of it not running you can see the crack its near the one edge of the nut(thats not a crack in the tail piece its a casting mark but weird that its in the same spot lol)
and here it is running
Old Nov 23, 2008 | 10:38 PM
annabelle's Avatar
J B Weld possibly?
Old Nov 23, 2008 | 10:45 PM
itr.#1446's Avatar
thats what i am trying tomorrow but i dont feel its gonna work
Old Nov 23, 2008 | 11:12 PM
annabelle's Avatar
Temps should be ok. Switching to manual will be $$.
Old Nov 23, 2008 | 11:14 PM
itr.#1446's Avatar
I don't thin the crack is just right there i think it does beyond where the two casings meet.
Old Nov 23, 2008 | 11:22 PM
1-5-3-6-2-4's Avatar
100% overtighened the fitting and cracked the case. that tranny cooler line fitting is Female NPT. you canrun it in until the case splits. that looks exactly like what happened there. its a tappered thread you run it in too far and the fitting threadskeep getting larger and the case hole does not. something has to give. weakest link. you have to be very careful with aluminum case holes. seen it before. that case is NFG. better weight your options. a recase overhaul is a minimum. don't bother trying to fix its a waste of time. and will only ever be temporary. it'll leak again and again.
Old Nov 23, 2008 | 11:23 PM
annabelle's Avatar
Good luck with the fix. I hope you are wrong and it's not to deep or long. However, with the fluid leaking, it looks like it went all the way through.
Old Nov 24, 2008 | 12:02 AM
Tortured's Avatar
It can be welded. I would try to weld it first before dumping 3k to 6k on a new or rebuilt trans. You will probably need to seperate the the case from the tail though. That spot is not a high stress area so you should be fine there but if you have never welded aluminum have someone who knows what they are doing weld it. You will need to cut a groove in the crack and fill it with weld. Grind it down smooth then get some flat stock and weld that across the crack, betwwen the fitting and the tail piece, for strength.
Old Nov 24, 2008 | 12:06 AM
itr.#1446's Avatar
My friends dad has welded cast aluminum intake manifolds for me before like you just described, the other problem is that i didn't mention yet is i put in a transgo shift kit and thats not working right i am getting alot of slipping going on when trying to move. Idk if its from the leak but i doubt it. I pretty much f'ed my trans all up you can say.
