Cracked injectors while running a Triple Dog on an 06 CTD?
Old Jul 4, 2007 | 08:30 PM
Jim Dynomite's Avatar
Been reading about a lot of guys with cracked injectors lately, and I was wonderin' if anyone with just a BDTD (no stacking) has had a problem with cracked injectors on an 06 CTD.
Inquiring minds want to know .
.................Jim
Old Jul 4, 2007 | 09:17 PM
Pooter's Avatar
Not sure if the bully dog adds pressure or not, but id be more worried about the other boxes that add pressue...
Typically timing/duration boxes arent as "aggressive" without stacking a pressue box, or one that adds pressure/duration/timing.
BUT with any aftermarket product theres always the problem of warranty
You could putt around with the BD on the lowest settings, and might have an injector issue, then be kind of up a creek after they see the box has been on your truck...
Old Jul 4, 2007 | 09:25 PM
Rpainter's Avatar
bullydog to my knowledge does not add pressure due to the fact it does not plug into the rail sensor.
Old Jul 4, 2007 | 09:26 PM
I don't care as much about the warranty as being broke down on the side of the road on a vacation trip.
Nothin' more embarrassing as your whole family setting up camp on the side of the interstate .
Just curious if I'm in a group of guys who should really be concerned that I'm in jeopardy of ruining my engine.
Anyone else with a Triple Dog?
............BTW, Happy 4th of July
....Jim
Old Jul 4, 2007 | 09:32 PM
Pooter's Avatar
....Jim
I was just tossing the warranty thing out there, I know alot of guys either dont know, or dont care. I dont really mind either, I know if you play, you pay.
I have had the Triple dog on my '05, dont have it on currently, but ill probably load it again sometime soon, havent had any issues with it...
Old Jul 4, 2007 | 11:57 PM
StrokeThisCTD's Avatar
Crazy larry adds pressure
I have a BD Triple dog for sale, i traded my truck saturday so its for sale. I ran it for probably 65,000 miles, mostly on the performance setting and i had no injector problems. i replaced a lift pump when the truck had 71,000 miles on it. not sure if that was from the triple dog or if it was just a bad lift pump
Old Jul 5, 2007 | 06:57 AM
jrussell's Avatar
It's a downloader so it doesn't plug into anything (except the OBDII port while you're programming the ECM).
The injectors are going to be working overtime anytime you start adding more fuel with any box/programmer. If you're really worried about it then the best bet is to keep it stock.
Old Jul 5, 2007 | 11:26 PM
That's my question. "SHOULD" I be worried. (Not yelling). I just wanna see if there are others with injector problems with a BDTD.
TIA.................Jim
Old Jul 6, 2007 | 01:39 AM
jwb600's Avatar
ive heard that the scary larry program cracks injectors. that was said by a few people. but thats not the only module that ive heard that will do it either
Old Jul 6, 2007 | 06:14 PM
zuki_dan's Avatar
I have been running my triple dog for 15K miles and have not had a problem, I even ran crazy larry before I stacked mine. I have had my rail pressure gauge since stock and have not noticed a difference in rail pressure on any settings while using just the Triple Dog.
Old Jul 6, 2007 | 08:01 PM
Great info! Thank you very much Dan.
..............Jim
Old Jul 6, 2007 | 08:24 PM
cromulius's Avatar
I put the xzt on mine to get some mileage that never really showed up except maybe on the highway. I am going back to stock (see motor dropping oil) after this injector deal. I know the box might not have been the problem but the motor has plenty of power as it is.
Old Jul 6, 2007 | 09:16 PM
TrkEnvy's Avatar
does the smarty increase pressure? and can you run just a smarty or do you have to stack it with something?
acook
22
Sep 23, 2006 12:46 PM
Syndicate
18
Sep 16, 2006 12:51 AM
RamWheelsBy4
Sep 17, 2005 01:43 PM
JUSTIN1MC
Aug 12, 2005 12:01 PM
