Cracked Injectors
Old Mar 5, 2006 | 08:59 PM
uruiamnew's Avatar
Cracked Injectors
I have an 04.5 HO 6 speed. At 33k an injector broke and filled the crankcase with diesel. #5 injector was split popping off @5000psi. Since it has been fixed it has had an occilating sound. The other day @ 55k same thing, diesel all in my oil and that mixture pouring out the blow-by and getting all over my truck. They replaced injectors 3 and 4. 4 was split? and 3 looked like it was fixing to break? I don't know how you can tell that but anyway. Now the motor does not have that occilating sound. Has anyone else had this trouble? I run an Edge box ECD1000C. I tried the ejd3000a but the truck did not run and pull as well. Thanks, Chris
Old Mar 5, 2006 | 09:24 PM
AK RAM's Avatar
Well, anything is a possibility, but folks have been running the EZ for years now and never a word of cracked injectors. Just to be safe, I would probably look for something else that is duration only maybe?
Old Mar 5, 2006 | 10:29 PM
no_6_oh_no's Avatar
Pressure box + stock HPCR injectors = BAD news. Period!
Too many problems for it to be an isolated instance. Run it on the lower settings and team it with a timing/duration box and you will have a lot better results. Either that or some high dollar tips that won't crack under the higher pressures.
Old Mar 6, 2006 | 07:42 AM
MikeyB's Avatar
Your running a pressure box designed for the SO/HO engines and not the 600's. The earlier engines run at a lower rail pressure than the 600's. With this box set to kill it will damage the injectors and or pressure relief valve.
MikeyB
Old Mar 6, 2006 | 07:53 AM
uruiamnew's Avatar
I have also had the pressure relief valve go twice, but never put the two together.
Old Mar 6, 2006 | 12:14 PM
Smkn600CTD's Avatar
You have the wrong EZ box.
You need 1000D, not 1000C, which is for the 03-05.
1000D is for the 04.5.
BigJohnston
Oct 13, 2009 03:17 PM
klx650a2
Apr 20, 2009 05:25 PM
Jim Dynomite
Jul 6, 2007 09:16 PM
Warlord
36
Dec 4, 2006 09:30 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
