Is this covered under 100k engine warranty
Old Mar 16, 2005 | 08:11 PM
Bowman's Avatar
Unhappy Is this covered under 100k engine warranty
Folks,
I’m having issues with my first Dodge diesel at only a year of ownership…
Not sure if I am covered under warranty or not. If anyone has gone through this, please let me know.
I bought a 2004.5 diesel last year(February). I have 40k miles on it(a lot of trips to the deer lease). Yesterday, my check engine light came on and stayed on. I got the code and it says..
The PCM has determined that the input voltage from the fuel rail pressure sensor is out of range. ( code # P0191)
I tried to talk with my dealer today to see if it was covered under the 100k engine warranty. They would not tell me much over the phone. So I thought I would go there early in the morning to see. I want to drive it out of town this weekend, but I'm leery now. The service guy said it is fine to drive until the check engine light starts flashing. I don’t want to be in Tim-buck-two when that happens.
Thanx folks,
David
Old Mar 16, 2005 | 08:17 PM
rjordan's Avatar
it should be as it is part of the engines injection system (i think??) i know the injection pumps on the second gens are covered on the 100k warrenty
Old Mar 16, 2005 | 09:11 PM
Bubba_CTD's Avatar
From: From Texas; Staioned in WA; Transplanted to AZ
Not much help as far as the code itself... but wehter it's covered by the 100K warranty or not, even though you're just past the 3/36 bumper to bumper, you're still well within the 7/70 powertrain.
Old Mar 16, 2005 | 09:13 PM
bumpytruck's Avatar
Look down a little farther here and someone lists that P0191 code or whatever # you gave.Might be a wire rubbing on an A/C line or something like that.
Old Mar 16, 2005 | 10:17 PM
Bowman's Avatar
Well, I went out and saw that one of my off road light wires(insulated) looked to be touching a set of wires by the brake resesovoir/firewall area. I moved the wire away from this area. I turned the key over . The engine light came on and then started blinking. I turned off the key, then started the truck. The light went off.
Not sure what happened. The code is still there though.
David
Old Mar 17, 2005 | 09:12 AM
Bubba_CTD's Avatar
The light will go away after a certain number of successfull startups (3 I think) and the code itself will go away after more... 10 or so.
Old Mar 17, 2005 | 09:28 AM
bigblock2stroke's Avatar
Rail pressure sensor is definitely covered under 100k/5 year warranty.
Dealer needs to check your truck to make sure you haven't had a pressure box plugged in that sent the rail pressure over the limit in the PCM. If you've always been stock, you won't have a prob.
Old Mar 17, 2005 | 06:24 PM
hoser's Avatar
any injection component is covered under the 5/160 DIESEL ENGINE EMISSIONS warrenty.
Old Mar 19, 2005 | 09:44 AM
eastmentCTD600's Avatar
Lightbulb P0191
David
I too have code P0191, but my check engine light is not on. I think it is a coincidence that your check engine light decided to flash just after you played with the wires at the firewll area
- unless you just happened to have a bad connetion at the fire wall AND when you moved the wires for your extra lights it jiggled just the right wire which contains the signal for the fuel rail pressure sensor -
By the way P0191 is discussed in the last few weeks on this forum, I posted it because I had the code but no CK engine light. do a search on P0191 within the last 2 weeks and you'll find it. There was a guy who had it and got it fixed. HIS fix was, and please take this with a grain of salt, the delaer had found some wires rubbing the AC lines - I don't know if the wires were the signal wires for the rail pressure sensor or if the wires were rubbed through to copper and shorting.
Good luck.
I'll be bringing mine in next time I'm out of town to get it checked out - I'll post if the dealer can do anything good.
Old Mar 19, 2005 | 01:07 PM
I've seen the ac rubbing thing to. Except there are a few more sensors than just the rail pressure sensor on the ac clutch circuit. When it happend to subject truck, it had cam/crank sensor faults too. It would misfire really bad when it happened but you had to about drive it over a parking block to get it to act up. Very difficult to diagnose, but worth looking into. It took us forever to figure it out.
thatguy
24
Jan 19, 2010 04:43 PM
Mark Hodowanec
Feb 13, 2008 09:13 PM
Tommy93w350
Jun 20, 2005 04:51 PM
030303
Dec 1, 2004 06:58 PM
chrismez
Nov 8, 2004 06:38 AM
