Turbo leaking oil,,, Is it covered under warranty???
Old Jun 15, 2005 | 06:02 PM
Tommy93w350's Avatar
Hey guys my 2001 CTD auto has oil leaking into the intake side of the turbo. I pulled off the air hose to remove the silencer ring and the propeller is covered in oil. It is also running down the air pipe.
Is the turbo covered under warranty??
Old Jun 15, 2005 | 08:36 PM
AAmeeting's Avatar
5 years 100,000 miles
Old Jun 15, 2005 | 09:37 PM
graphitecumnz's Avatar
Isn't the turbo considered a 'wear' item??
Old Jun 17, 2005 | 08:20 PM
DieselGoose's Avatar
Hey Tommy when you figure that out let me know. I had oil on my turbo as well on the inside.
Old Jun 17, 2005 | 09:05 PM
Huff nPuff's Avatar
Re: Turbo leaking oil,,, Is it covered under warranty???
Dont replace the charger until you check the blowby bottle,if its full of oil restricting the blowby exiting the tube this will cause exessive blowby pressure in the crankcase, which may cause the turbos to blow oil into the intake,There are other reasons for exessive blowby pressure,if you don't have the bottle make sure the hose isn't kinked or restricted.
Old Jun 20, 2005 | 07:21 AM
Joe Diesel's Avatar
I just noticed this weekend that I have oil on the turbo, but its on the exhaust end of the turbo, anything I should check ?? I've looked but I couldn't see where it was coming from.
Old Jun 20, 2005 | 04:51 PM
I checked the vent bottle and hose, clean and breathing.
I took it to the dealer today and Dodge is going to replace the whole turbo!!! FREE!!!!! $1,590.00 for the complete unit. I'm tickled, but worried at the same time. Why did the oil leak? What caused it!
They ordered the parts today and will install them Thursday. I'll keep ya'll posted.
Check inside of turbo for oil. if your truck has under 100,000 miles or less than 5 years old, its covered under factory warranty.
BNC04
34
Oct 13, 2006 04:53 PM
JIT
Jan 9, 2006 05:59 PM
Bowman
Mar 19, 2005 01:07 PM
030303
Dec 1, 2004 06:58 PM
chrismez
Nov 8, 2004 06:38 AM
