Coolant/Water Mix
Old Aug 22, 2008 | 04:19 PM
06RAM2500's Avatar
Coolant/Water Mix
Heard that you can't use distilled w/ G-05 coolants. So what can I use-spring, tap, or RO?
Old Aug 22, 2008 | 04:40 PM
#2 only's Avatar
Don't believe everything you hear.
I have used traditional coolant for 500,00 miles on my 2nd gen with no issues and 255,000 miles on my 3rd gen with no issues.
If you have low miles consider Evans coolant.It controls the heat spiking alot better than the water based coolant.
Old Aug 22, 2008 | 08:51 PM
glocklove's Avatar
"If you have low miles consider Evans coolant.It controls the heat spiking alot better than the water based coolant."
So does this mean you should not use Evens if you have a lot of miles?
Old Aug 23, 2008 | 03:26 AM
TexasCTD's Avatar
Guess im in trouble then...
I run Zerez G-05 and distilled water 50/50 mixed. Why would that be a problem?
HT3500
Competition / Pulls / OffRoad
Nov 30, 2007 12:00 PM
BC847
Sep 14, 2007 04:46 AM
Fergavs
Aug 22, 2007 10:21 PM
dieselfuelonly
Apr 9, 2007 12:03 PM
wanadieseltoo
Feb 19, 2003 09:01 AM
