Coolant for 03's and 04's
Guest
Posts: n/a
Hey I just noticed something. I opened the hood today and looked at the coolant level. Three things:
1. Coolant level is fine, thanks.
2. Coolant is pink
3. There is a warning on the cap that says the truck uses special coolant only.
What's up with the warning. Can someone give some insight here? I didn't see that on my old one. Is there an addative required similar to FW-16 for the Fords or something?
2. Coolant is pink
Guest
Posts: n/a
Re:Coolant for 03's and 04's
the coolant is 50,000 mile coolant. A couple days ago mine started leaking and i will tell you all now, go out to yuor trucks a tighten the tube going into the block heater, Those nimrods at the factory didnt tighten them all which causes leaks. Mine was so loose i could move it with my hand :
[quote author=BIGCUMMINZ link=board=20;threadid=23601;start=0#msg222279 date=1071188612]
[/quote]You're the second person I've read on here thats reported a leak there. Mine was ok.
From Cummins:
http://www.cummins.com/na/pages/en/p...530004AC33EA57
Do I need to use a coolant additive in my Dodge Ram?
We do not recommend an additive for the Cummins engine used in the Dodge Ram. Coolant additives are used to protect liners from cavitation and since the engine in the Dodge Turbo Diesel has no liners, it does not require an additive.
Also from Cummins
What does antifreeze do, and what are Cummins recommendations on concentration?
The primary purpose of antifreeze is to lower the freeze point of the coolant. Additional performance characteristics of coolants that are affected by the use of antifreeze include boiling point and vapor pressure. A 50/50 mixture of antifreeze and water provides optimum boiling point and freeze point protection for engines. Antifreeze concentration in excess of 60 percent must never be used since it increases the possibility of forming cooling system gel which results as silicates precipitate out of solution. However, concentration of antifreeze less than 40 percent increases the possibility of coolant freezing and liner pitting. Therefore, Cummins recommends an antifreeze range of 40 percent to 60 percent. Fluids presently used in antifreezes are ethylene glycol (EG) and propylene glycol (PG). Diesel engine antifreezes have primarily used EG products because they are less expensive than PG products. Some antifreeze applications require less toxic substances which have driven the use of PG. Engine-related applications of PG primarily have been applications where environmental concerns have disallowed the use of the more common EG products. For more information, refer to Cummins Coolant Requirements and Maintenance, Section 7, Bulletin 3666132.
Here is some more information on this from Dodge:
It goes on to say this:
So there you have it
CAUTION: MoparT Antifreeze/Coolant, 5
Year/100,000 Mile Formula (MS-9769) may not be
mixed with any other type of antifreeze. Mixing of
coolants other than specified (non-HOAT or other
HOAT), may result in engine damage that may not
be covered under the new vehicle warranty, and
decreased corrosion protection.
Mopar Antifreeze/Coolant, 5
Year/100,000 Mile Formula (MS-9769), or the equivalent
ethylene glycol base coolant with organic corrosion
inhibitors (called HOAT, for Hybrid Organic
Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when
mixed with 50% Ethylene Glycol and 50% distilled
water to obtain a freeze point of -37°C (-35°F). If it
loses color or becomes contaminated, drain, flush,
and replace with fresh properly mixed coolant solution.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
TexasHardcore
Jul 27, 2004 11:23 PM
