Compression Cavitation?
Old May 6, 2010 | 11:04 AM
btak's Avatar
I am new to Dodge and the 5.9 Cummins and have a question on coolant requirements. In the past I have run Powerstroke7.3 and it was important to keep the coolant in range to prevent compression cavitation. The additive I have used my Ford is made by Cummins Filtration and is labeled DCA4.
Are there any coolant additives that should be kept up on these 5.9 engines to prevent compression cavitaion? I have not seen much discussion on this issue; I know alot of commercial diesel trucks use DCA4 / DCA2. Any thoughts on this?
Old May 6, 2010 | 12:16 PM
Dr.Dizzle's Avatar
The G-05 coolant specified for the Dodge Ram CTD utilizes hybrid organic acid technology (HOAT) to minimize inhibitor depletion. It contains a blend of inhibitors designed to give a high degree of corrosion protection to engine components. Due to its nitrite content, this product is very effective for extended use without the need for supplemental additives. Therefore, there is no need for any additional additives during the service life of the coolant.
Old May 6, 2010 | 12:34 PM
Jeff in TD's Avatar
If I recall correctly, the Ford was a wet liner design, and needed the additive. The Cummins does not.
HOAT coolant like Zerex G-05 changed every 5 years is all you need.
Old May 6, 2010 | 12:36 PM
Dr.Dizzle's Avatar
That would be correct regarding the Zerex G-05 coolant. The Ford 7.3 required the SCA, however, I am not aware if it was a wet liner design.
Old May 6, 2010 | 01:18 PM
btak's Avatar
Great so with a HOAT coolant change ever 5 years, unlimited miles...?
Old May 6, 2010 | 01:41 PM
Dr.Dizzle's Avatar
The Mopar factory fill (HOAT) coolant provides 5 year or 100,000 mile protection. The Zerex G-05 coolant provides protection for up to 5 years / 150,000 miles. Just so you are aware, G-05 HOAT coolant is available in 3 brands.
1). Zerex G-05 Coolant - in a gold gallon jug, yellow/gold colored fluid usually available at NAPA and Carquest.
2). Mopar Hoat Coolant Embittered -in a black gallon jug, either orange or pink dyed fluid, avaialable at Chrysler/Jeep/Dodge dealers.
3). Motorcraft Premium Gold Coolant (PART VC-7A) yellow/gold colored fluid, available at Ford dealers and a few parts stores.
Old May 6, 2010 | 02:23 PM
Boris-MC1's Avatar
Thanks Dr.
I also needed the info.
B
Old May 6, 2010 | 10:54 PM
Jeff in TD's Avatar
According to Zerex's web page, their G-05 is the Dodge factory coolant, just dyed red.
Oct 16, 2006 03:30 PM
chinook country
19
Jul 17, 2006 08:42 PM
Kampnnut
Jun 23, 2006 01:10 PM
vavtx
Feb 28, 2005 07:55 AM
Stamey
Mar 30, 2004 06:54 AM
