Compareing injector pumps
Old Nov 22, 2006 | 07:43 PM
GSP's Avatar
GSP
I have a 99 with a vp 44. What injector pump is in the new trucks?
How about the chevy Duramax, does it have a bosch pump just like or simular to what the newer dodge has?
Reason I ask is , on another forum some know-it-all says the duramax and dodge have the same bosch injector pump
Old Nov 22, 2006 | 08:14 PM
bluebull's Avatar
Pretty much the same CP3 in both trucks. Ours use a lift pump for primeing the fuel filter after change out, the Duramax use a bulb type primer. Our trucks will die if the lift pump dies because of fuel restriction caused by lift pump.
Old Nov 22, 2006 | 09:24 PM
GSP's Avatar
GSP
So do those CP3's not realy need a lift pump like our vp44 do to keep them lubed with inlet fuel pressure?
Also are you newer truck guys running a fuel lube like powerservice, stanadyne or 2 stroke oil to keep the CP3 and valves lubed like us vp44 guys are?
Or does the CP3 not have a lube and wear and die problem like the vp44
Old Nov 22, 2006 | 10:19 PM
FMB's Avatar
FMB
In order.... I dunno .... Oh, yeah, Stanadyne here... It sure does have the lube issue, lose your lift pump and your CP3 soon follows.
Old Nov 23, 2006 | 07:35 AM
bluebull's Avatar
It's not so much a lube problem, the early CP3's had gaskets in the wrong place. Bosch has corrected that on the later models, I think some where around mid 05 models, so any truck built in the 05 model year and older could be susceptable.
Old Nov 23, 2006 | 07:39 AM
bluebull's Avatar
The cp3 will run just as long and as well without a lift pump as the cp3 on a duramax. When the lift pump dies on a dodge it causes too much restriction and starves the engine of fuel so it quits running. If you removed the lift pump and could get prime the truck would run again. Never experienced this, just going off of what I have been told, and read.
Old Nov 24, 2006 | 12:15 AM
duratothemax's Avatar
hes right
CR cummins CP3 just has the outlet tube in a slightly different location I beleive than a dmax CP3. Otherwise they are more or less quite similar.
Ilikebikes
Dec 11, 2006 10:13 PM
azdodge
13
Jun 5, 2006 11:25 PM
torque6
Jul 3, 2005 01:48 PM
ChokedUp
Oct 15, 2004 05:10 PM
apache
Jul 2, 2003 11:27 PM
