coldest start without block heater
Old Jan 29, 2019 | 12:43 PM
anpconnors's Avatar
Weatherman has us all lathered up about the polar vortex. Question for those in REAL cold areas, how cold will it start without block heater? Fuel is winterized + power service white. 142,000 miles original injectors. Thank you a be safe!
Old Jan 30, 2019 | 05:03 AM
mcgyverit's Avatar
I got mine started at 5F with no real problems, few extra cranks is all. I would recommend getting a block heater though at some point for future use, not hard to install yourself and only about $50-60
Old Jan 30, 2019 | 12:06 PM
StealthDiesel's Avatar
LOL, it depends what you mean by "cold". Cold to me in Canada, is different to cold to someone in southern California.
If you don't have a block heater and/or cord, I hope you have adequate antifreeze rating in the cooling system.
Also critical is the engine oil. Conventional 15W-40 engine oil is not good at all for below 0F /-18C cold starts. It's really thick and the engine will sound like hell until it warms up.
15W-40 synthetic is much better, Synthetic 5W-40 or syth 0W-40 is even better.
I used conventional 10w-30 for winter before but I wouldn't work the engine hard, towing, on 10W-30. Its too thin.
Old Jan 31, 2019 | 06:47 PM
KATOOM's Avatar
Its unofficially stated that a cold Cummins ISB can start in temperatures down as low as -20*F without the help of plugging the block heater. I would presume that is going to be dependent on battery condition too...
Old Jan 31, 2019 | 08:52 PM
Curious...
If you have the capability of plugging in your truck, then why don't you ?
My truck will start on really cold days as well, with or without the block heater.
It starts so much smoother with the block heater, sounds better (not making a bunch of rattling diesel noises), warms up faster. When I start my truck up in very cold weather, without plugging it in, it sounds like it's gonna blow up. Noisy, smoky LOUD. None of that happens when it's been plugged in overnight.
I see no negative to plugging it in, as I believe that's why the factory put them in our trucks.
Old Jan 31, 2019 | 09:56 PM
BarryG's Avatar
I have started my 2001 without the block heater in as low as -29 deg f without issue. May find out the same this weekend in the 2017. Alamosa last night was -23 f and was that low several times in the last week, will be there this weekend though not sure it will be that cold though. Due to an ecm issue years ago I found on multiple occasions my 01 would not start without the grid heaters much below zero.
Old Feb 1, 2019 | 10:01 AM
johnh's Avatar
I stay inside when the temp is below 30
Old Feb 1, 2019 | 10:41 AM
anpconnors's Avatar
Thanks for all the replies! Do have block heater and used it, just had to jockey other cars in the AM when leaving for work. Running 5W40 syn oil , winter front, Odyssey batteries, so in theory could have started without plugging in. Miss the 2000 Dodge with the three cylinder idle, did sound like it was going to implode!
Old Feb 2, 2019 | 10:54 AM
The 2003+ Common Rail Cummins are excellent in cold weather. Your truck should automatically go into a high idle when it's below approx. -5C/28F.
The 2004+ Cummins also have a manual high idle feature. The engine idle speed can be manually controlled with the cruise control function.
At engine idle, enable cruise control and you can manually raise and lower the engine idle speed.
On your 2006 automatic, the dealer can enable this feature in the ECM, or any aftermarket programmer can enable this.
Old Feb 2, 2019 | 11:22 AM
I have started my Cummins 12 and 24Vs in weather down to -25F without plugging them in.
If I get the chance, I usually plug them in for an hour or two and they start much smoother.
Plugging them in all night is a waste of electricity in my eyes, anything over 3 or 4 hours is just melting the snow off the hood and making my electric bill higher.
Old Feb 2, 2019 | 10:40 PM
ofcmarc's Avatar
My old 1st gen would start at -45* unplugged without question. I sounded horrible and I hated to do it but in an emergency, it was reliable. My 3rd gen will pull off -25 or -30* unplugged if the batteries are in good shape (batteries appear to be the limiting factor on my 3rd gen) and again, it sounds horrible and I don't like to do it. You are better off to plug them in if at all possible. It's just better on everything in the long run. I give mine 2-3 hours plugged in for anything below about +10* down to -20*. Colder than that I leave them plugged in 24/7 just in case. That big 1100lb block of iron under the hood takes a LOOOOOONG time to thaw out after a cold soak when the mercury is hiding in the bottom of the thermometer.
Old Feb 10, 2019 | 10:34 AM
wheelo90's Avatar
I've done -14 here unplugged. Well, technically I had it plugged it, but the wife unplugged the cord and seemingly forgot to plug it back in... Fired up like a champ. Gave it a minute for the oil pressure to stabilize, then kicked it into high idle mode, which is 1100 rpm. Ran inside, got dressed, and off to work we roll.
Biggest determining factor, BATTERY HEALTH! I can't stress enough how important it is to have some good 1,000CCA batteries with clean connections.
JaimeG
Mar 26, 2009 06:58 AM
supersonictoys
Nov 8, 2008 09:17 PM
Oldschooldodge
Nov 14, 2007 09:10 AM
FirstDodge
Jan 2, 2007 03:34 PM
diesel_burner
Feb 23, 2006 04:01 PM
