Code PO236 AND PO111
Old Jun 23, 2010 | 02:11 AM
cougar1559's Avatar
Red face Code PO236 AND PO111
This is an interesting deal here. If you get PO236 and PO111, Remove the plug from the multi function sensor that is in the middle of the intake manifold. This is MAF/Charged air temp/Boost pressure all in one. If you look in the end of the PLUG you will see that there is a defect in the plastic preventing the black/orange female pin from being all the way in. So it is sitting on top of the male pin on the sensor. I have had to cut the plastic a bit to get the female pin to seat. Ten minutes and no more codes. This is pretty common out there.
04.5 shorty 5 inch, superchips, the rest stock.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
