code p2149
Old Oct 4, 2010 | 09:23 PM
railroaderone's Avatar
code p2149
truck thru a P 2149 code today injector 4 or 6 shorted high or low. Is this covered under warnty. What are the most likely cause.
Thanks
Old Oct 4, 2010 | 10:29 PM
tallboy's Avatar
Either your #4 or #6 injectors are bad. Search for the error 2149 on here and you should find a lot of info. I lost mine last year, #4 injector. The suggestion was to replace the valve cover as the wires can short out in the gasket and cause that code to trip. I did that first (not covered by warranty) and it seemed to fix it, then 50 miles down the road it tripped again and the injector bad (covered by warranty).
Good luck
Old Oct 5, 2010 | 08:47 AM
cbrahs's Avatar
it is injector 4,5 or 6. if it is less than 5 years old and less than 100k miles it should be a warranty issue.
Old Oct 5, 2010 | 08:48 AM
cbrahs's Avatar
Good luck
I have done many of these and 99.9% of the time it is the injector and not the harness
Old Oct 5, 2010 | 11:28 AM
gpshemi's Avatar
If he's running the smarty with gauges and stuff...will they warranty the injectors? I would think not once they see that stuff.
Old Oct 6, 2010 | 10:23 PM
dneilson's Avatar
My truck threw this code at me a couple of weeks ago. I made it a few miles to where I was going, sometimes running on 3 cylinders. 30 minutes later, after calling a shop and trying to figure out what was going on, I started up the truck and it ran fine. I did go home and replace the fuel filter which was filthy. I have since put over 2,ooo miles on it without a problem and no additional codes. Should I worry? Or, just not go anywhere I wouldn't want to be stranded?
Old Oct 7, 2010 | 06:43 AM
DiezelSmoke's Avatar
Originally Posted by dneilson
Should I worry?
YES, mine did the same took about 6 months until I got it to a dealer when it would do it so they could see. Be prepared to drive directly to the dealer and don't turn the truck off, and insist they plug into it imediatly.
Old Nov 22, 2010 | 09:27 PM
ramcneal's Avatar
How common is this problem? Twice now my truck has had injectors replaced under warranty. Both times it has ruined a family vacation with the last occurring on Saturday. My truck is an '06 2500 with 75k miles and I'm concerned about the cost once I pass the 100k mark. Not to mention not being confident in the vehicle which until last year has been very reliable.
Old Nov 23, 2010 | 07:15 PM
banyon's Avatar
My 06 did this today. The dealer said this code means contaminants in the fuel rail. I changed the fuel filter & put the engine on 2500 for about three minutes. It cleared up & runs fine now. I think one of the injectors was trying to stick open. The injectors were put in at 88,000 miles & now I have 125,000 miles on it. Injectors shouldn`t go bad this often. On the other hand, maybe it won`t give me anymore trouble.
Remnik
20
Jul 23, 2017 03:10 PM
bdaniel
15
Jan 30, 2011 04:17 PM
Remnik
Feb 16, 2009 12:12 AM
kjw
Jan 18, 2009 09:22 PM
mudder500
Jan 11, 2009 07:54 AM
