p2149 code
Old Jan 9, 2009 | 07:26 PM
mudder500's Avatar
p2149 code
Alright truck was fine before i started modding it and now it wont run on the 4-5-6 cylinder and throws a high pressure common rail code. Anybody have a clue. I check and put grease in all electric fittings also. Im bout to have a cow
Old Jan 10, 2009 | 08:34 PM
eastmentCTD600's Avatar
What mods did you perform?
Initially it sounds like you knocked loos a wiring connector or tapped into the wrong harness. Go back to where you were prior to mods (if possible) and see if you have the same issue.
Good luck.
Old Jan 10, 2009 | 08:36 PM
cbrahs's Avatar
Mudder does not have enough room to type on the mods he has done! LOL... Hope ya git r fixd mudder. I want pics!
Old Jan 10, 2009 | 09:11 PM
chrleb1's Avatar
Tell us what you have... from the sounds of it.... sounds like you have an edge juice on it.
Old Jan 11, 2009 | 07:54 AM
mudder500's Avatar
Nope I don't have an edge crap of a prgrammer!
Bad injector solienold is the problem. Now I got to get it fixed.
Truck has:
Evil twin cp3
Silverbullet over 480
Opie trans
Studs
Valve springs
110ddp injectors
Smarty
Remnik
20
Jul 23, 2017 03:10 PM
bdaniel
15
Jan 30, 2011 04:17 PM
railroaderone
Nov 23, 2010 07:15 PM
Remnik
Feb 16, 2009 12:12 AM
kjw
Jan 18, 2009 09:22 PM
