clutch master cyliinder or slave cylinder???
Old Nov 20, 2007 | 12:40 PM
stock600's Avatar
It all makes sense now i will be going for the upgrade, i have a call in right now for peter they said he was out going to the doctor. I had to go out and study the firwall again i see what you mean, looks like you can twist or pull the resivoir out. How is it attached under the dash and to the pedal? Is your noisey at idle now? And thanks
Old Nov 20, 2007 | 01:43 PM
cgmorgan06's Avatar
There is just a clip that attaches the rod to the pedal. And also some wires which I think are the ones for starting the truck making sure the clutch is depressed. No mine is not noisy at idle. I called Jeramy at texasdieselshop.com in Madisonville, TX and he shipped me one at I got it the next day. They are an authorized southbend dealer and I got mine for $255 shipped.
Old Nov 20, 2007 | 02:25 PM
stock600's Avatar
I think im done asking questions i sure appresiate the information. Peter at sb called me back and also drive it for a while see what happens. I only have maybe 100 miles on it now, he said the new hydros are adjustable where the factory unit obviously is not. When i told him it starts to engauge right off the floor thats what made him think it could be the hydros. As for the noise he said it was due to the very strong disk center harmonics and as the springs ware in a little it will get better, and IF not let him know! Last thing is yours adj. as he said and did you monkey with it to get it just right? thanks ryan
Old Nov 20, 2007 | 02:44 PM
cgmorgan06's Avatar
Yes mine is adjustable, but I dont have it exactly where I would like for it to be just yet. I just havent taken the time to do that. Hope everything works out for you.
Old Dec 22, 2007 | 06:10 AM
Katmandu's Avatar
Question
I need to replace just the Slave cylinder on my 2nd Gen.
How does one bleed the slave cylinder ???
Old Dec 22, 2007 | 07:27 AM
dogger's Avatar
Interlock wiring
Originally Posted by cgmorgan06
I got the slave and master from Texas Diesel Shop out of Madisonville for $255 shipped. The hardest part of the install was getting the old one out. Since the system is already bled I guess that is why it has its own resevoir. The stock resevoir is mounted on top of the clutch master cylinder and I guess therefore is not reusable. The SB one has a hose running to the resevoir from the master cylinder. I just zip tied the resevoir the brake lines that are right there (I think thats what they are without looking at it). Let me know if you have any other questions bout it.
I getting ready to do exactly the same thing in about 1 week. How the heck do you get the connector apart for the 2 wire connector for clutch interlock switch? I've pulled, pushed, shoved, yanked. cursed, swore and many other actions but the connector still defies my best attempts to separate it.
L8r,.......dogger
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Fishbait
Jun 6, 2006 12:34 PM
banks twinram
Feb 28, 2005 02:43 PM
Heeler00
Feb 18, 2004 01:52 PM
