Clarification needed on my 03's engine...
Old Nov 15, 2007 | 07:15 AM
MikeyB's Avatar
Originally Posted by infulleffect
Just so I can start getting the "lingo" down here...is the turbo elbow the cast piece right off the exhaust side of the turbo and also connects with a V band to the down-pipe?
Also with regards to the dp on an 03 model the cast flange is only 3in...on the "turbo elbow"...is that correct? I just want to make sure I get it all straight.
I see that they make a 304 SS for an 06 model...would that be cat back only?
Is there any other reputable companies that make a 4in SS exhaust for our trucks?
Thanks,
Jim
That is correct.
I believe the cast flange is a 3.5". Add to the confusion but some of the very early built trucks came with the 4" elbow. August/September 2002 time frame.
There are other companies out there, like Magnaflow that makes SS systems, but personally MBRP is one of the better ones.
MikeyB
Old Nov 15, 2007 | 01:09 PM
rip 112's Avatar
I think Silverline makes one too, but I've put my faith in the MBRP Stacks!!! They rock!!! Full exhaust with the 4" down included.
Old Nov 15, 2007 | 03:30 PM
mad1's Avatar
silverline, volant and corsa make a 304 exhaust. the corsa will be the most money and will cost you $1000.00 or more, the silverline around $600-650 if you search. call extreme they sell the silverline. there is also dpp they also sell a 304 for your truck.
Old Nov 15, 2007 | 04:15 PM
bigblock2stroke's Avatar
Originally Posted by rip 112
No tell them its the 03-04 HO non 600. Or tell em its the 305/555 motor. 03-04 had a standard output, which you don't have.
but the exhaust is the same on a HO or standard output for 03/04 model years
when the 325 came out in 2004.5, they got rid of the HO moniker cause they were all 325's
Old Nov 15, 2007 | 04:33 PM
rip 112's Avatar
Greetings,
I recently purchased an 03 Ram 3500 and beforing doing so I got a dealer print out, using the VIN, to see what options the truck had...especially the engine and trans. Although I knew somethings about the truck I didn't know nearly as much as I know now...so my confusion comes with regards to my engine. The dealer print out states I have a 305 HO motor...the valve cover states 305...but after reading some other posts on here and trying to order a MBRP exhaust; I've been told that a 325 is the HO not the 305. So I guess the question is do I have a HO motor or not and what are the differences that make it so different for the firment of an exhaust?
Thanks in advance,
Jim
This is why I was stating he didn't have the SO or the 600, but had a HO. Yes the exhaust is the same on the SO and 03-04 HOs.
Old Nov 15, 2007 | 06:35 PM
infulleffect's Avatar
I need my bed complete so stacks are not an option...but thanks for the input
I will look into the other exhaust mentioned above...I also contacted MBRP to see if they have any old stock or know of anyone with a T304 full system for my truck...just waiting on a reply
Old Nov 16, 2007 | 06:38 PM
ClackClack's Avatar
Well,................they did. And it came with a kitty.
...and they're 235's. see my sig.
but they get great milage!
Old Nov 19, 2007 | 06:54 PM
Well no luck with finding a T304 MBRP system at any of the larger dealers So I guess I am looking into: silverline, volant, or magnaflow for a T304 system.
Thanks for the help folks your input as usual is extremely helpful.
fade94
Aug 4, 2010 06:44 PM
ppsi
Jan 27, 2004 12:54 PM
Sticks
Nov 23, 2003 02:04 PM
DPG
Mar 22, 2003 12:08 AM
