Clarification needed on my 03's engine...
Greetings,
I recently purchased an 03 Ram 3500 and beforing doing so I got a dealer print out, using the VIN, to see what options the truck had...especially the engine and trans. Although I knew somethings about the truck I didn't know nearly as much as I know now...so my confusion comes with regards to my engine. The dealer print out states I have a 305 HO motor...the valve cover states 305...but after reading some other posts on here and trying to order a MBRP exhaust; I've been told that a 325 is the HO not the 305. So I guess the question is do I have a HO motor or not and what are the differences that make it so different for the firment of an exhaust?
Thanks in advance,
Jim
Thanks in advance,
Jim
The '03-04 SO/HO uses the same exhaust system. So like Rip said just order the MBRP
exhaust for a '03-04 model only.
MikeyB
MikeyB
The '03 and '04 HO MBRP exhaust has a 4" pipe. It necks down to 3.5 inch at the exhaust elbow. Best thing is to get a '04.5 exhaust elbow and order the pipe for an '04.5 truck. Or just don't worry about it and get the '03, '04 system with the 3.5 inch connector ring at the turbo.
If you plan to get the stainless pipe get the 304 stainless. The muffler is 304 anyway, but the pipe comes in either 409 or 304. 409 rusts. They also make a very nice stainless tip for the 4 inch pipe that can take a lot of road sand blasting and won't rust. Mine is a double wall tip that is 5 inch OD (4 inch ID).
John
John
John
John
Also...I just tried locating a 304 SS system for an 04 and they all say 409...can I use the HO exhaust system on my truck?
Thanks,
Jim
No, most systems for the '04.5 and newer are cat back systems.
The MBRP systems are a full 4" on the '03-04. So just order the system for the '03-04 and you will be fine. As Raspy mentioned you could upgrade the turbo elbow to a full 4" also by using the elbow off of a '04.5+ model. But isn't mandatory.
I don't think MBRP makes a T304 system for our trucks anymore. Only T409.
MikeyB
MikeyB
Back to your question about HO motors.
For '03 and '04, there was an HO and an SO. These designations told you which motor you have as they made tow different versions. Simple.
Starting with Job 1 for CY '04, they only made one motor, the 325/600. So, no need for the two designations. There was only ONE motor. So, it's neither an SO or an HO, it's an '04.5 motor OR just call it a 325/600.
You say there was an HO and SO for 03 and 04- I didn't know they made the SO in 04 at all, even for the first part of the production year??
MikeyB
MikeyB
Also with regards to the dp on an 03 model the cast flange is only 3in...on the "turbo elbow"...is that correct? I just want to make sure I get it all straight.
I see that they make a 304 SS for an 06 model...would that be cat back only?
Is there any other reputable companies that make a 4in SS exhaust for our trucks?
Thanks,
Jim
