Charging system failure
Old Feb 28, 2016 | 03:17 PM
2005Ram3500's Avatar
Good afternoon everybody. Here's my situation. I noticed for about 5-6 weeks when turning the key to on that the battery gauge was a bit low. Then sometimes while driving it would drop below norm then come back up a few minutes later. Then one day it dropped to zero and stayed there. I had 30 miles to get home, the radio shut off, then the emergency brake light came on. Anyway, I've replaced both batteries and the alternator. When I turn the key to on the gauge shows maybe 10. When I start the motor the gauge drops to about 6. I've checked for chafed or broken wires but can't find anything. I appreciate any help on this situation.
At the same time all this was happening I got a code for the crankshaft position sensor and I replaced it. Is there a connection between the two?
Bill
Old Feb 28, 2016 | 04:44 PM
CRF450R RIDER's Avatar
you inspect the cross over cable? also check all of your grounds
Old Feb 29, 2016 | 07:52 AM
Yes I checked the cross over and all other wires that I can get to and see easily look fine. Seems like something was going bad over a period of time. Do you think it would be the ECM?
Diesel-Dan
20
Sep 22, 2019 09:34 PM
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
