Change Hubs while doing U-Joints?
Old Jun 16, 2009 | 04:38 PM
Mark Hodowanec's Avatar
My axle u-joints are really BAD. Will finally do them this weekend. I'll try to be careful & not pull hub bearing apart (will probably use PS method). At 115K miles, should I be replacing the bearings anyway? Alot of labor to get there, but don't feel like trowing away $500 if I don't have to.
Old Jun 16, 2009 | 05:20 PM
dodge35000's Avatar
If they are not squeaking or grinding you may still be OK. I have heard of people unscrewing the ABS sensor and injecting grease into the bearing to increase the longevity of the unit bearing. However, that all depends on if you can get the unit bearing out of the steering knuckle without the unit bearing seperating.
Old Jun 16, 2009 | 08:18 PM
D-Roc's Avatar
Get yourself a free spin kit and change everything out just once...ball joints too. Then your longevity will increase for sure.
Old Jun 16, 2009 | 08:41 PM
blue_bandit's Avatar
i don't know if the 3rd and 2nd gens are the same, but i bolted on an old brake rotor and beat the pi$$ out of it to get my hub loose
91oldranchtruck
Jan 31, 2011 09:45 AM
trik396
Aug 30, 2010 07:28 AM
Hummin Cummins
Apr 13, 2008 04:35 PM
