Truck died while doing 50mph..
Old Aug 27, 2010 | 04:21 PM
trik396's Avatar
Luckily I was able to pull off the road and into a large parking lot after I put her in neutral. It's darn hard to steer and stop these trucks with no power.
Anyhow, my only code I pulled and cleared was a high fuel rail pressure (p0088) I believe. Why would this cause a shut down?
This is the first time anything like this has happened in 70,000+ miles. I'm running SmartyJr and nothing else. I did clean engine compartment earlier in the day so I'm thinking maybe some moisture caused a freak-out? She started right back up and no problems since.
Any opinions?
Old Aug 27, 2010 | 04:51 PM
madhat's Avatar
Administrator/Jarhead
Yeah, it could be water. I had an issue one time after I washed the engine compartment.
See if the code comes back. Let us know...
Old Aug 27, 2010 | 07:17 PM
trik396's Avatar
Thanks... will do.
Old Aug 30, 2010 | 04:50 AM
rnemovr's Avatar
how far had you drove after you washed it?
Old Aug 30, 2010 | 07:28 AM
trik396's Avatar
About ten miles... I would've assumed that any moisture would evaporate by then due to engine heat.
Good news is I put over a hundred miles since then without a problem. No other codes have popped up.
ctrials
Nov 7, 2007 08:38 AM
dgm
Jan 2, 2006 10:26 AM
Gene007
Dec 23, 2005 01:20 PM
olivmatt
Dec 19, 2003 07:00 AM
nailzsn
Jun 8, 2003 11:12 PM
