Can you blow out injector tubes?
Old Feb 11, 2009 | 02:45 PM
sallyman1's Avatar
can you blow out injector tunes backwards? the tubes that go from the line to the injector have a filter in them called a edge filter. instead of replacing mine at $70 a piece ($430 for 6) i thought i could blow mine out backwards to dislodge any metal debris in them. is this wise to do?
Old Feb 11, 2009 | 03:16 PM
zuki_dan's Avatar
Are they plugged up?
I normally blow all lines out with brake cleaner and the injector tubes when I install injectors.
Old Feb 11, 2009 | 03:32 PM
sallyman1's Avatar
which way do u blow them? direction of fuel travel or opposite? if i blow with my mouth i cant get air through. or do i need a compressor to do this? how restricted should they be?
Old Feb 11, 2009 | 04:10 PM
CamperAndy's Avatar
Well unless you make a couple of thousand psi with your mouth you will not get much flow.
Back flush is the way to clean them but you have to be very clean in everything you do as you do not want to push dirt into the downstream side of the filter.
Old Feb 11, 2009 | 04:12 PM
sallyman1's Avatar
lol. thats what i mean. doesnt pay to try then|? a person will nevr know how restricted a tube is then?
Old Feb 11, 2009 | 08:31 PM
homewrecker's Avatar
They only cost about $22 a piece from Cummins.
Old Feb 12, 2009 | 08:27 AM
sallyman1's Avatar
lol not here in canada. they are $70 each here in canada.
Old Feb 12, 2009 | 03:46 PM
zuki_dan's Avatar
I haven't tried to blow through them with my mouth but I spray the brake cleaner through the tube the correct way first then backwards and it doesn't have trouble spraying through.
Old Feb 12, 2009 | 04:22 PM
sallyman1's Avatar
cool. ill try that. thanks zuki dan
BIGOKIE
19
Jul 27, 2013 08:45 AM
Haulin_in_Dixie
14
Nov 15, 2004 01:34 AM
More Power
Jan 10, 2004 10:55 AM
hellotbone
Sep 16, 2003 01:52 PM
