can i use bio-diesel
Old Nov 16, 2007 | 06:30 PM
firecrazy720's Avatar
can I use boi-diesel in my truck? I am thinking of making my own dose anyone have an opinion?
Old Nov 16, 2007 | 06:35 PM
roadgeneral's Avatar
Yes you can..............no problem. I use biodiesel B20 all the time. Fuel filter looks fine, truck runs great.
Old Nov 17, 2007 | 09:38 AM
Bleu Goat's Avatar
I have been running biodiesel about a year and just had an injector go bad. The dealer suggested that I go back to straight diesel and that some dealers would use the biodiesel as an excuse to not honor warranties.
Old Nov 17, 2007 | 09:45 AM
John Faughn's Avatar
It varies mostly from system to system & % of bio , that 04 is it a common rail ? I've read that the high pressure causes the bio to polymerize [ turn stringy is the technical term ] , so a lower % about 2-5% gives your all the lube additive you need but because of the high pressure you lose the ability to go higher , maybe in near the future they will modify additives to go higher % .
Bio being relatively new , the quality has not stabilized , lots of bad batches out there .
Old Nov 17, 2007 | 09:50 AM
Ronby's Avatar
I run B20 biodiesel in my 04 and don't have any problems.
Old Nov 17, 2007 | 01:24 PM
gunny's Avatar
Been running bio in Cummins, Cat, Duramax and the Navistar engine for a few years now. Never have had any fuel system problems.
Old Nov 17, 2007 | 01:29 PM
ccoop769's Avatar
I run b15 all the time cause mostly that all you can find on interstates. Truck seems to run fine i guess.
Old Nov 17, 2007 | 04:47 PM
I was thinking of making my own bio is anyone making there own? I have a 2005 model and my buddy has a 2007 3500.
Old Nov 17, 2007 | 06:25 PM
kelley15's Avatar
https://www.dieseltruckresource.com/...splay.php?f=92
Look around in there for some good info. /\
Old Nov 17, 2007 | 07:15 PM
DiEseLjunKy's Avatar
Cummins now says you can run up to B30 in all their ISB, ISM, ISX engines.
Old Nov 17, 2007 | 09:09 PM
bekim's Avatar
I have and am running on b99 with NO problems at all. It produces less power, resulting in lower mileage than usual (1-1.5 mpg less). Bio reduces engine vibration, and noise just a bit. Bio also smells kinda like stir fry when it burns. The risks are completely exaggerated IMHO
Mike
Old Nov 17, 2007 | 10:19 PM
rwpor's Avatar
read the Lubricity study done by Spicer on the diesel place web site, it will suprize you. Good news for bio dieselas a lubricant, also read the post and responses. It came out #1 against the other additives and good old 2 cycle ash less come out 7th both beating a lot of the famous additives. the lab tests measured the Wear scar. enjoy
Totallyrad
Jul 19, 2011 07:41 AM
04ctd
Sep 27, 2005 12:52 AM
OldSmokey
Sep 20, 2005 09:50 PM
Commatoze
Sep 10, 2004 06:30 PM
